Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > General BMW
General BMW
Use this forum to talk about general BMW news/stories and to chat with fellow enthusiasts about the direction that BMW is going in for their cars and/or motorcycles!
Old 12-03-2012, 06:00 PM
TropicsX5's Avatar
TropicsX5 TropicsX5 is offline
Mein Auto: Z4 X5 325I
Increased Battery Discharge message
hi, getting, Increased Battery Discharge message on 2010 328I convertible, vehicle has 11, 500 miles, does battery need to be replaced? , when the car s turned off i don't see anything that could be draining the battery... thanks
2011 X5 Premium
2010 328i Hard top convertible
2007 Z4
2007 X5
2003 325
2003 X5
Old 12-04-2012, 06:45 AM
vern vern is offline
Send a message via AIM to vern
Mein Auto: 01 330ci 05 530i 06 X3
Is the car going into the sleep mode? Check led lights by the shift leaver-stop/start button they should go out in about 15 minutes .Did you install any aftermarket electronics that aren't compatible with BMW?
cheers
vern
2012 335iA Blk. Sapphire- Sport-Blk. Dakota Leather/Red-Brushed Alum.Trim-DAP-PP-CWP Rear View Camera-BMW Asst w/Enhanced BT&USB-High Gloss Blk.Trim Hghight-PSP-Speed Limit Info-Tech. Pkg-PDC-Rear Manual Sun Shades-SAT-Variable Sport Steering-Wheel Locks- Rubber Matts-Euro Del 5/14/12-Redelivery 7/16/12 2006 X3 3.0iA 4/6 Silver Gray Metallic-Black Leather-Nav-PP-SP-Xenon Headlights-PDC-Heated Front Seats-Privacy Glass-Servotronic Steering-Premium Sound System-R R R- Wheel Locks- Rubber Matts
Old 12-04-2012, 08:26 AM
gpburdell gpburdell is offline
Mein Auto: 2010 335i Cabrio
http://bimmerfest.com/forums/showthread.php?t=650653
http://bimmerfest.com/forums/showthread.php?t=659890
http://bimmerfest.com/forums/showthread.php?t=584978
One of the biggest benefits of a forum is that frequently a question has already been answered several times, and you can get your answer with just a few clicks rather than having to wait for people to see your question and post answers again.
Most likely answer: Buy a battery tender to extend the life of your new battery when you buy it. You might be able to limp along for a while with your existing battery if you keep it topped up with the tender, but you do increasingly risk getting stuck somewhere.
Two to three years is a little on the shorter end of a typically car battery lifetime but not unheard of; especially if your 2010 is a 2009 build making it older than say an August 2010 build. Your relatively low annual mileage suggests it either sits undriven for days at a time or if driven more often the trips are very short; both of these are hard on a battery.
