have a red car on right side NAV display ... - Bimmerfest - BMW Forums
Old 12-04-2012, 08:49 PM
jafcorrea jafcorrea is offline
Mein Auto: 760i and Z3 1.9l
....... "check control" asking .... brake fluid and microfilters, I already add fluid is full and change all filters a week ago, how can I reset this message or do I need to take to the dealer?
Thanks all for the good info.......
Correa
Old 12-04-2012, 09:02 PM
Seven11's Avatar
Seven11 Seven11 is offline
President
Mein Auto: BMW
u dont have to take to the dealer but u do have to have an OBD reader
i see u are from san francisco, take your car to 19th ave and Quintara, and i am sure those guys will reset that for u... maybe for a small fee, maybe free. its a 1 min job
'08 BMW 535i - Sport - Sport Trans - JB4 - Catless DPs - Intake - E85 -
'07 SUZUKI GSXR-750 - Gray/Black - Akrapovic Titanium Exhaust -
'03 BMW 525i - Sport -
'98 Ford Expedition - 5.4L - 4WD - Eddie Bauer - 8 seater -
'03 BMW 745i - GONE -
'09 HONDA CBR600RR - GONE -
Old 12-04-2012, 09:04 PM
19th ave and Quintara ...Okay, thanks
Correa
Old 12-04-2012, 09:27 PM
cmpcpro cmpcpro is offline
Mein Auto: Nothing
You cant reset these from the hidden menu?
Old 12-04-2012, 09:46 PM
...... how do I go to the hidden menu?
Correa
Old 12-04-2012, 09:48 PM
Mein Auto: Nothing
When car is running or ignition is on I believe you hold down the trip button until the gauges light up.. I know thats what I did to reset my brake pads bringing up the red car.
Old 12-04-2012, 10:19 PM
Seven11's Avatar
President
Mein Auto: BMW
i dont have the car anymore
i totally forgot about the hidden menu
if u cant get it reset thru it, i am pretty sure u can thou, just hit up those guys
Old 12-05-2012, 05:13 AM
dommm dommm is offline
Mein Auto: 2011 550ix
1=Sit in the drivers seat,doors shut and key out of slot.
2=Put key into slot and press the start button so the ignition is on.(not started)(do not put foot on brake)
3=Wait 5-7 seconds,then press and hold the button in the cluster top of speedo dial.
4=Hold this button for 5-7 seconds and a menu should come up in the middle of the speedo dial when this happens let go of the button and then to scroll through the menu using the same button in the speedo dial until you come to the item you need to change.
5=Then press and hold the same button again for 5-7 seconds and the next menu should come up in the rev counter dial,scroll through this menu to reset and press and hold for the last time.
This should reset the item you need changed.
PS: This worked for my car but your model may differ. gl
Old 12-05-2012, 05:52 AM
GeorgeT's Avatar
GeorgeT GeorgeT is offline
Mein Auto: '07 750i BMW; '03 Z4 BMW
The brake system is supposed to have the fluid flushed and replaced every two years, that mabe why the light came on. Just adding fluid doesn't solve the problem.
Old 12-05-2012, 07:23 AM
wjjklj's Avatar
wjjklj wjjklj is online now
Mein Auto: 2013 BMW M5
When you get to the hidden menu as directed above, you need to go to item #19 which is unlock. You hold down the trip reset stalk for a second and it will ask you for the unlock code. The code is found by adding the last 5 digits of your VIN. This unlocks all functions of the hidden menu.
