Looking to get some great BMW parts for your car? Get the lastest info on sponsor group buys, new products or simply ask a site sponsor a question here!
Old 12-04-2012, 06:02 AM
AndyM's Avatar
AndyM AndyM is offline
Suede Master
Mein Auto: '02 3.0i Z3 Coupe
LeatherZ - Wheel Pins; 2 for the price of 1!
One is good, two is better! Limited Time Only: 2 S3 Wheel Pins for the price of one!
The perfect stocking stuffer! Get a set of 2 S3 Wheel Pins for $20!
For a limited time, LeatherZ is offering two (2) wheel pins for $20. WHile one Wheel Pin makes installing a wheel easier, 2 makes it that much easier. Why are two Wheel Pins better? when using one wheel pin, you still have align the holes in the wheel with those on the hub. This can be difficult while installing that first lugbolt. With 2 Wheel Pins, you slide the wheel on the pins and install the lugbolts.
Removing and replacing your wheels for cleaning, performing routine maintenance or upgrades, switching between street and track tires, or even mounting a spare tire can be a real pain. It's easy to drop your wheel onto one of your brake calipers, leaving you with a permanent flaw in your wheel.
Frequently, it's difficult to align the lug bolt holes in the wheel with the holes in the wheel hub. Enter the S3 Wheel Pin. S3 Wheel Pins are 4 and 3/4 inches long with a rounded nose that will make sliding your wheels on and off extremely easy. Made of stainless steel and finished to a beautiful luster, the S3 Wheel Pin is ready to work for you. Just remove one of your lug bolts, screw the S3 in, and then remove the wheel. The wheel will slide right off the S3. Remount the wheel in the reverse order. The Wheel Pin is small enough that it will not eat up valuable cargo space or weight. It even fits perfectly in your LeatherZ OEM Oil Baggie. Most importantly, the S3 is thoughtfully designed with just enough threads so that there is no way to screw it too far into the wheel hub. Buy one pin for each of your BMWs.
Follow us on Facebook for news and current promotions
08 E82 135i | 02 Z3 Coupe | 01 R1100S
