E90/E91/E92/E93 (2006 - 2013)
Old 12-04-2012, 09:39 AM
SarinD SarinD is offline
Mein Auto: 335i
Broke Window regulator on 335i
My rear driver side window won't close on 2007 335i. I can hear the motor working and clicking but the window doesn't come up. I do believe it is the regulator. Has anyone run into this? Also, could you share a DIY link so that I can replace it without having to pay a fortune. Thanks
Old 12-04-2012, 09:42 AM
Mein Auto: 335i
Thanks in advance
Old 12-04-2012, 11:14 AM
jakobv84 jakobv84 is offline
Mein Auto: '07 E90 BMW 335i
Same thing happened to me but I just took it to an Indy so can't help you there.
'07 E90 335i, Cobb Stage 1
Old 12-04-2012, 11:48 AM
ctuna ctuna is offline
Mein Auto: 325xi wagon
Check the fuses first.
If you feel you can DIY there are DIY's in the DIY and maintenance section
here
http://www.e90post.com/forums/forumdisplay.php?f=16
Oops its making a noise so proceed to the DIY's
http://www.e90post.com/forums/search...rchid=24731042
there are more there to search = window regulator
Old 12-04-2012, 02:31 PM
DSXMachina's Avatar
Automaticallyparsinglinks
This is a good DIY for someone looking to save some money. Watch for the semi-hidden screws, get past the tricky maneuvering and you've got it made. You may have to buy an oem regulator, but check with your local parts shop and see if Dorman is making one for the 335 yet. It's probably the same throughout the E9x series (coupes and verts excepted).
window regulator diy, window regulator repair
