E46 (1999 - 2006)
Old 12-04-2012, 11:14 AM
elcat elcat is offline
Mein Auto: 330I (2005)
water pump failure
Can hear water pump grinding on cold start up so expect it will have to be changed. This will be the second in under a year and less than 60k miles. car is 2005 330i. questions are why pump failure in the first place, second what are alternatives to OEM replacement. third, does so called "lifetime" coolant contribute to failures?
Old 12-04-2012, 11:21 AM
Toona79 Toona79 is offline
Mein Auto: 2003 325i
http://www.stewartcomponents.net/Mer...y_Code=BMWHPWP
thats the mac daddy of them all but you'll pay up front for it. saves you in the long run if you plan on keeping the car a while though
03' 325i ZSP ZPP
Old 12-04-2012, 09:28 PM
GoForthFast GoForthFast is offline
Mein Auto: '04 330Ci 6-speed
Maybe you're getting really cheap crap pumps? Chinese would explain your situation.
Old 12-04-2012, 11:59 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
This is in the E39 bestlinks ... lots of good information ... probably applies to the E46 M54 also:
- What brand of waterpump to buy (1)
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders.
See also: E39 Bestlinks & How to easily find what you need, in seconds!
