Old 12-04-2012, 11:53 AM
SpartanGA SpartanGA is offline
Mein Auto: 2007 550i, 2011 335i Vert
Water trickling noise from AC vents and water spray!!
I have been hearing a water trickling sound from the instrument panel...the vents basically.
The sound does not go away when you turn off the AC, but it does go away if you turn off the entire system.
When you turn the fan to HIGH, it blew water out the vents!! I should say liquid, I assume water...no odor.
2007 550i.
Any ideas? I am about to call my local Indy shop and ask them.
Jim
2007 550i Sport - White - Tan
Old 12-04-2012, 01:01 PM
235301 235301 is offline
Mein Auto: 06 525xi Monaco Blue
Yes, I know exactly what you are talking about and you need to be careful otherwise you are looking at frying your head unit(this happened to me). I would not use the AC until the issue is resolved. That water in the vents will likely get into the electronics in the dash and fry something, likely the head unit. This happened to me twice on long, hot drives. On the second instance it fried the head unit(radio). And if it does fry it you are looking at upwards of $1500-$2k for replacement.
The only "solution" I heard about was that it had something to do with the throttle cable and it was actuating something. The solution is to tie wrap the throttle cable. There is a apparently a SB on it. My memory is foggy on it so I wouldn't take what I said as gospel.
Good luck!
Old 05-28-2013, 04:42 PM
starfire starfire is offline
Mein Auto: 99 528i
I have the same problem. 08 535 with 78k. With the AC on low sometimes it sounds like a babling brook. It literally sounds just like water trickling. If I hit MAX, it blows hard like it should but will blow out droplets of water. It eventually stops blowing the water. If I turn it back to low the running water sound stops for a while but might come back. I cant imagine what in the world would make it sound like running water. Any help or ideas would be appreciated.
Old 05-28-2013, 04:49 PM
schpenxel schpenxel is offline
DIY'er
Mein Auto: 2004 545i
I would assume the drain for the condensation off of the evaporator is clogged.
Check and see if you're getting water dripping under the car when the AC is on. You should. If not, it's definitely clogged.
Found this also:
https://www.bimmerfest.com/forums/sh...d.php?t=290777
Old 05-28-2013, 06:14 PM
Yea. The drain is clogged. It has a flap on the end that sticks shut.
The drain hose is next to the exhaust behind heat shields. I flipped it up and a cup of water came out.
Jim
Old 05-28-2013, 06:50 PM
tashi tashi is offline
ED experienced member
Mein Auto: 2010 BMW 528i
There is a bulletin on it. This happened to my 2010 528i as soon as it was redelivered after ED. Took it in and they replaced the hose plug.
2010 528i - Auto - Space Gray - Nat Brown - NAV - HUD - HD Radio - Xenon - Rear/Side Shades - PDC - ipod/usb - ED 10/19/2009
Previously: 2004 325i JetBlk/Blk, SP, Step, NAV, PDC, Moon - ED 12/05/2003
Old 05-29-2013, 07:25 AM
Mein Auto: 99 528i
Thanks guys, I will check this later this evening. Can you tell me again exactly where it is located and how hard it is to get to?
Old 05-31-2013, 07:12 AM
boramkiv's Avatar
boramkiv boramkiv is offline
Propellers Up Front
Check this thread out.
Note the pdf and what it contains.
This is probably the issue.
