E46 (1999 - 2006)
Old 12-04-2012, 06:55 PM
Beanman Beanman is offline
Mein Auto: 2000 540i sport
delayed cranking on start up?
Looking for help on my daughters 99 328i she is having trouble when starting, turns key to start position all dash lights come on but does not crank, no sound, holds in that position for several seconds then it cranks and fires up, sometimes she has to do it this routine a number of times. Sometimes if I hookup a battery charger/starter under the hood to her remote battery post it will fire up and sometimes no? Ideas Thanks in advance.
Old 12-04-2012, 08:30 PM
E46_Ci E46_Ci is online now
Mein Auto: 2005 325Ci + ZPP/ZSP/ZCW
Mine was doing this... Replaced the battery and it hasn't done it since.
Alpinweiß 2005 325Ci
Spacegrau 2007 X5 3.0Si
Old 12-05-2012, 12:31 AM
heztheone heztheone is offline
Mein Auto: 330i ZHP M/T
do the following:
1- check the voltage on the battery, if it reads 14v when running it's fine, anything less or equal to 12.5v, u could have a dying battery.
2- if so, disconnect battery, pull the VR off the back of the alternator and inspect the brushes. If they are worn out it'll be pretty obvious, change them
3- recharge the battery and redo point (1)
Give a man a fish and you feed him for a day. Give a man a Chef and he feeds him for a lifetime
delayed start, no cranking, won't start
