E36 (1991 - 1999)
Old 12-05-2012, 04:25 AM
meplusbmw meplusbmw is offline
Mein Auto: 1998 bmw 323is coupe
1998 323 is 2dr coupe audio system help needed PLEASE!
Hi, my name is Tri. I own a 98 323is. When I got it I was told the radio worked, all I needed to do was connect the wires. I take out the stock radio and I see that the wires have been cut. The radio wires are cut( isn't there suppose to be a black piece at the end that connects to an adapter for a aftermarket radio?) And the antenna wire is also cut. Someone please help. I bought a metra 7085-90 radio wiring harness adapter from Amazon. I'm so confused. I love my car. Someone please help!! It'd be much appreciated
Sent from my LG-P999 using Bimmer App
Old 12-05-2012, 04:26 AM
As you can see I don't know much about my BMW but I'm learning!!
Old 12-05-2012, 08:22 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Send a message via Skype™ to petriej
You need a new harness it sounds like. There's wiring diagrams out there somewhere. Try searching. I'd suspect someone stole an aftermarket unit out of the car, and someone just put the OEM radio back in to make it look nice.
Good luck.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by batmobeamer View Post
So in other words **** you haha. Batmobeamer $
2005 X5 4.8is Le Mans/Black/6spd Steptragic
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual
1997 328iC Schwarz II/K/K 5 Speed Manual SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6 Speed Manual RIP 04/2011
Old 12-06-2012, 01:36 PM
I bought an adapter so I can hook up an aftermarket radio. I read that I have to connect the adapter to the wires from the aftermarket radio then connect it to the car wires. Was there a harness at the end of the wires?(potentially might have been cut off) and the antenna wire was also cut. Do I have to buy the harness and antenna harness too? I just want to hear my beautiful system :'(
Old 12-06-2012, 04:03 PM
This is what it looks like. The blue wire is the RCA to the amp. I have no idea what the black wire with the wires is, the speaker wires are the twisted colored wires right? Now isn't the suppose to be a harness with the speaker wires so I could plug in the adapter? Factory harness>>70-8590>>aftermarket radio wires. Or am I wrong
Old 12-06-2012, 04:31 PM
E36 Phantom's Avatar
E36 Phantom E36 Phantom is online now
King of the Ballers
Mein Auto: Dreier, Fünfer & Siebener
Exactly, there's supposed to be connector on the end to go to the radio. Looks like someone cut it, either a thief or moron DIYer.
Two options:
A) Go to a junkyard and snip off the connector with about 6" of wire and solder back together. This will allow you to easily connect a stock radio as is or any aftermarket with the adapter, and be much more elegant.
B) Use your adapter harness and snip off the factory side and splice. You'll be able to use many aftermarket radios but not all and no factory radios.
Sent from my LG Revolution 4G using BimmerApp
Chad // 2001 BMW 740i M-Sport // 2000 BMW 540i Sport // 1997 BMW 328i Premium //
E38 16" Style 5 Basketweaves, M52 Parts, and New Gaskets/Seals for Sale!! PM for info. .
Originally Posted by SlimKlim View Post
You're a derbanana
Old 12-06-2012, 05:58 PM
Can you explain option b please? Would I need go to the junkyard?
Old 12-06-2012, 05:59 PM
I don't mind if I can't use a factory. I have a Kenwood radio I would like to use. Do I need to buy the amp integration harness also?
