Engine off Cabin Heat and turbo cooling question - Bimmerfest - BMW Forums
Old 12-04-2012, 10:39 AM
jburke4689 jburke4689 is offline
Mein Auto: 2007 335i
In the N54 the electric water pump will pump coolant through the turbo to cool it and I believe that it will cool the turbo if required even with the engine off as directed by the DME. My question is that if you push the "REST" button to heat the interior of the car while the engine if off, does that also provide a manual method of cooling the turbo since it uses the coolant pump.
Old 12-04-2012, 05:02 PM
TXFred TXFred is offline
Mein Auto: 2008 335i Convertible
Originally Posted by jburke4689 View Post
In the N54 the electric water pump will pump coolant through the turbo to cool it.
Are you sure about that? I've never heard the water pump run after shutdown. Then again, I've never listened for it. I'm not questioning your knowledge, just seeking confirmation.
One nice thing about a water cooled turbo is that, if the plumbing is done correctly, the coolant will continue to circulate through the turbo via convection. So a pump may not be needed.
I live in fear of turbo coking. At some point, I plan to add an after-oiler to my car. Here's an example. http://www.racerpartswholesale.com/p...4964/Accusumps
I plan to mount it forward of the radiator, so that when I shut down, a charge of cool oil is pumped to the turbo bearings to quickly lower their temperature.
As far as your question goes, if the water pump is running, then coolant will be circulating through the turbos.
Frederic
Any idiot can be fast in a straight line. The corners are what separates the drivers from the commuters.
Old 12-04-2012, 05:28 PM
floydarogers's Avatar
Pedant and Curmudgeon
Mike Miller (Roundel) has confirmed it in a couple instances. He also says "it's very quiet". Sorry, can't remember which month/issue - they're up at my cabin.
As for whether the rest heat function's pump is the main one and will cool the turbo, don't know. My 335d has an auxiliary pump mounted on the left strut tower (about 8" below the top) that I understand is used on those (diesel) cars with the rest heat function - but then the M57 has a belt-driven pump. Can't find the aux pump on realoem.com for the 335i.
Old 12-04-2012, 06:19 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Yessir - there is 1 body of cooling water. But:
I've appreciated REST on many winter stops but don't remember turbos cooling then.
My cooling water can run through the turbos after a warm evening run, but there's no need for REST in that weather.
Old 12-04-2012, 08:48 PM
I looked under the hood of my 335i. There's no aux pump that I can see. The heater hoses run to the front of the engine. So I assume that Rest just activates the normal coolant pump.
Frederic
Old 12-04-2012, 10:09 PM
Yup - the electric water pump.
Old 12-05-2012, 07:55 AM
Here is a quote from the BMW N54 Engine Management Training course on the value and advantage of the electric water pump.
Component Protection
After-running of electric coolant pump = improved heat dissipation from engine switch off point. Allows protection of turbochargers by reduced oil "coking" during heat soak.
The schematic doesn't show any valve other than the thermostat so I guess pressing "REST" must run coolant through the turbochargers.
