E36 (1991 - 1999)
Old 11-29-2012, 06:57 PM
tchavera tchavera is offline
Mein Auto: 323is
top wont go up
hey guys, i have not seen the problem yet but the shop has a e36 convert coming in tomorrow and the top wont go up. All I know is that if you hit the switch nothing happens and if you manual try it only goes half way up. I figured a lot of you have encountered this so and advice or opinions are welcomed. I will constantly update until it's fixed. Thanks!
p.s. it's coming from another shop so I'm not sure how much they looked into it or what
Old 11-29-2012, 07:00 PM
dc_wright's Avatar
bimmerfest Supporting Member
See the Origami sticky
Old 11-30-2012, 09:46 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
I am intrigued by this part. If the motors are all disconnected, the top should go all the way up manually. I suppose there is a physical problem with the top geometry. A common problem spot is the cross bar (or whatever it's called).
GGC BMW CCA #443004
Join the BMW CCA!
2005 X5 4.8is Le Mans/Black/6spd Steptragic SOLD 3/2016
Old 11-30-2012, 11:53 AM
Mein Auto: 323is
sorry i did not read the sticky or even search for that matter. i realize there is a lot covered on this topic. i have not been able to look at the car yet but apparently it would close before until it got like 2 or 3 inches from fully sealed. anything cross your mind?
Old 11-30-2012, 12:39 PM
petriej's Avatar
If the car is a '97 or newer it has a fully auto top, which means the part that connects the front edge of the top to the windshield has a motor inside the top to latch it. If the top worked to that point and then stopped, it could be something as simple as a fried motor. Or it could be broken linkage cables. If that's the case, you'll have to open it up and replace them. There should be more than one thread on that subject around here somewhere. Be thankful the top is not closed with broken cables...
GGC BMW CCA #443004
Join the BMW CCA!
Old 11-30-2012, 02:57 PM
dc_wright's Avatar
Could also be a problem with micro switch 7. When it closes the top controller thinks the top is closed all the way and locked down. If it closes prematurely, the top stops there........
The E36 convertible adjust PDF file has a really good explanation of how the top mechanism works and what the micro switches do.
Old 12-01-2012, 05:20 PM
Mein Auto: 323is
okay well it was just a reset procedure needed. the prior shop was half way there i'm not sure why they couldn't do that. sorry for asking and not searching i figured it would be more difficult than turning the key and holding a button. thanks!!
Old 12-02-2012, 11:33 AM
petriej's Avatar
Sounds like you lucked out! Nice.
GGC BMW CCA #443004
Join the BMW CCA!
Old 12-02-2012, 12:56 PM
dc_wright's Avatar
Don't pop the champagne cork yet! Typically the top only needs to be reset when something else has caused it to lose track of where it is. Hopefully it was just something transient and it'll be good, but don't be shocked if they're back in a couple weeks.
Old 12-05-2012, 05:38 PM
Mein Auto: 323is
Will keep in mind!
Sent from my SCH-I500 using Bimmer App
