Battery Registration using DIS - Bimmerfest - BMW Forums
Old 10-26-2010, 02:41 PM
jbhoot jbhoot is offline
Mein Auto: 2006 750Li
Does anyone know how to register a new battery using DIS? I have seen a lot of posts saying that it has been done - but I cannot find how to do it. I have DIS but just cannot figure it out. I would really appreciate any help.
Old 10-26-2010, 02:50 PM
irokdastar383 irokdastar383 is offline
Account Under Review
Mein Auto: 745li
you need inpa
Old 10-26-2010, 09:31 PM
Thanks Rock Star. As you know I am in the process of getting INPA but I have DIS already. Take a look at the thread here #12
http://www.bimmerfest.com/forums/sho...y+registration
it seems like TJ and Kief have been able to register the battery with DIS. It looks like DIS gives you more options.
I read your thread on installing INPA - how difficult was it to install? did you have to use VMWare?
Old 10-26-2010, 10:27 PM
teejaylentz teejaylentz is offline
Mein Auto: 2002 745i
Sorry I didn't answer your PM - been busy. It has been a while since I have used DIS (thankfully I haven't had a reason to )... I still have the laptop sitting in my garage with it installed but haven't touched it in a while . Getting DIS working is quite involved requiring multiple steps to build out the VMWARE image and get the software on the host machine. DIS communicates over the network, so you need to setup the IP addresses appropriately and install a diagnostic head emulator that listens on the host machine. You also need INPA/EDIABAS installed on the host so that the daig head emulator can talk to your controller/interface. It's pretty involved and I don't have a step by step guide handy. Getting all the pieces together will take some effort (took me a couple days mainly just getting all the pieces, searching, and gathering info) - www.bmwecu.org used to have a FAQ on their site with step-by-step screenshots, but I can't seem to find it anymore. A quick search and I found this site that outlines the general steps but it leaves out a lot of it - it's a definite pain and not really worth it in my opinion unless you have a bunch of BMWs to fix and/or plan on doing some major module replacement (even then, if you want to reprogram the modules, DIS can't do that, you need another system called SSS which runs in a Windows environment): http://www.ow.no/index.php?option=co...=115&Itemid=13
I'd definitely recommend using INPA for the purpose of registering the battery.
Old 10-26-2010, 10:35 PM
To answer your other question - INPA runs on Windows and doesn't need VMWARE. You'll need to get an interface to connect to your car that will work with INPA (I bought mine online from someone in China for about $60 ~2 years ago).
Old 10-26-2010, 10:57 PM
Thanks TJ - and no problem on the PM. I do have DIS working, I also have the diag head - but I just can't work out how to register the battery. I also have SSS - but have not tried that yet. Maybe I will try that at the weekend.
Is there a place to download INPA? When you say interface - do you mean the VAG ODB-II cable?
Thanks again for your help.
Old 10-26-2010, 11:05 PM
This is the exact same one I have (I have no idea who this seller is - it's always a risk buying from these guys!):
http://cgi.ebay.com/ebaymotors/NEW-B...item255b90a96c
Sending you a PM...
Old 10-27-2010, 07:21 AM
hanssae hanssae is offline
Mein Auto: 2004 730D
You find it here : http://forums.bimmerforums.com/forum....php?t=1374483
Old 10-27-2010, 09:24 AM
Keif Keif is offline
Master Tinkerer
Mein Auto: 2007 Alpina B7
In DIS you go to service functions, then something else (maybe chassis?), then you can find the section for battery stuff. I'll break open the laptop later and look.
Black 2007 Alpina B7
Tension strut bushings
White 2007 Alpina B7
Supercharger clutch/bearings, replaced exhaust valve/pulled head, sunroof seal, 6000K angel eyes
Black 2002 BMW 745Li (sold)
KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator & mounting bracket gasket, sunroof seal, CCVs, plugs, sway bar bushings, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, sanded headlights...
Old 10-27-2010, 10:19 AM
tabuarasa tabuarasa is offline
Mein Auto: E65 745i (2002)
My car has a standard battery (110Ah), to replace BMW recommends AGM (90Ah).
Question: AGM is enough to register with INPA or will need to program in the dealer?
Old 10-29-2010, 06:57 AM
Master Tinkerer
I didn't find a place in INPA to change the battery rating, I'll look in DIS later and report back the proper path.
Old 10-29-2010, 08:15 AM
Mein Auto: 745li
keif i got a question. i got inpa and now i have the dis and everything i need for bmw like parts finder and wireing diagram. when i install dis do i need to do any special thing to make it work with inpa? thank you
Old 10-29-2010, 09:05 AM
Master Tinkerer
How much you have to do depends largely on what version you are running. Most of the v44 images have been boxed up pretty well and you won't have to do much, but there are a few things. Within DIS, check out the ediabas.ini settings, the network card settings, and stuff like that. Also, are you running the diaghead emulator? Have you made the proper modifications to ediabas.ini on the INPA side? There should be step by step instructions out there for setting up all this stuff, but those are some of the things you'll likely be poking around in. Assuming you're running DIS in a VM, make sure you have a virtual network set up in VMware using the proper .30 or .68 subnet (I can't recall off the top of my head which it is, but you'll find it in the steps).
Old 10-29-2010, 09:11 AM
Mein Auto: 745li
ill look into that i didint attempt to install yet . thanks alot keif
Old 10-30-2010, 10:52 PM
OK guys, so I found the menu to register the battery - but still cannot figure out how to register it. I can't double click the 'Register Battery Replacement' and the arrow in the bottom right of the screen does not light up green. I can select the 'Register Battery Replacement' but I cannot do anything else from there. Any ideas? I can do a lot of other stuff like turn on lights, open windows through DIS - but just not battery registration.
Old 12-05-2012, 02:35 PM
nasserkarbassi nasserkarbassi is offline
Mein Auto: BMW328i
DIS register battery replacement
Hi, u don't need to have right arrow GREEN, just go to Test Schedule and u can continue as it says.
