Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series > E30 (1982 - 1993)
E30 (1982 - 1993)
Old 12-05-2012, 04:05 PM
WickedFast.Inc WickedFast.Inc is offline
Go Fast or Go Home
Mein Auto: 1989 325I
Bad tps?
I have a feeling that my tps is bad or off cal the most predominate reason i can tell you is when doing a stomp test it takes several stomps and its when i release the pedal is the problem i have to let it spring back kinda hard for it to tell that a press was done which makes me think tps also causing my idle problem as i installed a new idle valve and it will not open it hums but when i start the car it fires all six maybe once and dies am i headed in the right direction? I dont want to put 80 bucks into the wrong part
Wicked Fast Entertainment
Old 12-05-2012, 09:14 PM
tim96 tim96 is offline
Mein Auto: bmw e30 320i
if you open the throttle with your hand you should hear the throttle switch click just past the throttle rest position. Maybe a previous owner adjusted the throttle stop screw thinking it was for the idle..
Old 12-06-2012, 03:02 AM
Nick323's Avatar
Nick323 Nick323 is offline
Nick's Toys
Mein Auto: 323i E30 2-door
Check throttle cable ! & return spring
If your throttle blade does not open completely when somebody steps on the padal, with carpets installed...
Then release the pedal slowly & the throttle blade should return to its stop automatically.
Don't take life too seriously; no one gets out alive !
