E46 (1999 - 2006)
Old 12-05-2012, 01:30 PM
dale9n dale9n is offline
Mein Auto: 2000 bmw 328i sedan
buying a scan tool...Peake??
My 328i is a late year 2000. it has the obd under the dash like the 2001 to 2007. so which one do i buy? Looking at the Peake scan tool. I found out that bmw changed mid year 2000 to the dash hook-up. I think i'm posta go with the newer type. Right?????
Old 12-05-2012, 01:37 PM
cvx5832 cvx5832 is online now
Mein Auto: 325Ci, 325Cic, C300
Assuming that year can use the BMW Scanner 1.4.0, I'd buy that. About 1/5th the price, and you can program with it too.
Old 12-05-2012, 01:58 PM
tcphoto tcphoto is offline
Mein Auto: '01 325Cic TiAg
I bought a Peake tool about a year ago and it's paid for itself many times over.
Old 12-05-2012, 02:11 PM
e46trj e46trj is offline
Mein Auto: e46
+1
I have one and love it. Paid for itself with coding the LCM to disable DRLs and code xenons.
After that several instances of SES, alarm coding and what not.
You can even see live data.
However, if you have a 20 pin connector under the bonnet you will need a 20 pin to 8 pin adapter as well for the bmw scanner 1.4 to work with your car.
Old 12-05-2012, 02:33 PM
MalibuMafiaV's Avatar
L4P
I bought a 11 dollar bluetooth OBD2 reader from amazon. Works fine.
http://www.luxury4play.com
2004 Maserati M128 GT
Old 12-06-2012, 03:48 AM
av98's Avatar
av98 av98 is offline
ZHP = Patlabor
Mein Auto: 330iZHP,Odyssey,MR2,Miata
Harbor Freight has some good OBDII scanners. I scored a $130 model for $70 during the black Friday deals.
Old 12-06-2012, 07:38 AM
Mein Auto: e46
BMW scanner 1.4 is $33 and can code the car too. Adapter may be around $10. Much worth the investment if you plan to keep the car for longer time.
code reader, engine check light, scan tool
