E90/E91/E92/E93 (2006 - 2013)
Old 12-06-2012, 05:57 AM
brewder brewder is offline
Mein Auto: '07 328xi
RPM dip and dive
Hello,
I have a 2007 E92 with 114k miles on the odo. I recently replaced the plugs around 90k miles..... This week I was on a long (500+ mile) trip and got off the interstate after about 3+ hours of continual driving. While sitting at the light, my car started to shake/shudder and the RPM guage was dipping from it's normal idle of 650rmp to below 500..
The car has never done this before and is fairly well maintained... It occassionally will shake a little just after it's been started especially after sitting all night in the cold.
I know ignition coils should be able to last until ~150k miles, but does anyone think this could be the issue??
Or could it be something like the "winter gas" switch over??
ps... I also use a bottle or two of Techron roughly every 3k miles... last usage probably 2k miles ago.
//Brew
//Brew
('07 E92 328xi / '08 E83 X3)
Old 12-06-2012, 06:39 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Originally Posted by brewder View Post
Hello,
It could be something like....a need to read codes to know where to start.
Do that / have it done; c'mon back....
Old 12-07-2012, 06:19 AM
Yeeeaaahh... I really need to break down and buy me that Bav Tech tool one of these days... I always assume that codes are thrown only when one of the idiot lights shines on the dash, but I know that's not true.
oh well, thanks for the reminder!
//Brew
Old 12-07-2012, 01:17 PM
fb88 fb88 is offline
Mein Auto: 2006 330xi
114k and you never replaced ignition coil? eventually Check Engine light would come on for misfire code if it's ignition coil, but that should be a permanent rough drive and not come and go.
Perhaps it's related to your spark plugs change.
Old 12-08-2012, 03:25 PM
Ilovemycar Ilovemycar is offline
wooohooo
Mein Auto: '08 335i coupe 6MT sport
I cannot help you resolve your issue, and I do wish you luck in figuring out what it was. However, I'd like to say that DSX warned me about the use of Techron, saying something like it is a strong medicine: only use it when you really have a need for it. Therefore, I have no plans to ever use it again, unless someone who knows what they're talking about recommends its use for whatever particular reason that may arise in the future.
Old 12-08-2012, 04:59 PM
Bimmer1995318ti's Avatar
Bimmer1995318ti Bimmer1995318ti is offline
Mein Auto: 1995 bimmer 318ti
What is techtron used for ?
Old 12-08-2012, 05:54 PM
Cleans injectors.
Old 12-08-2012, 08:18 PM
BMW Group Fuel System Cleaner Plus. SI B 13 05 06
PN 82 14 0 413 341
bmwcca.org editor recommends every 3k to 5k miles. I have not used in my car of 134k miles.
Since you are experiencing the problem, try it once.
dump it into an empty tank before filling up
Old 12-09-2012, 06:05 AM
MP3_E46's Avatar
MP3_E46 MP3_E46 is offline
Code/wrench Monkey
Mein Auto: Miata NC2
Spend $24 to pull codes: http://www.amazon.com/gp/product/B005NLQAHS
Hello,It occassionally will shake a little just after it's been started especially after sitting all night in the cold.
Mine does that at 11K miles. Unsure of the issue; I had guessed at the battery but that seems fine after charging with a CTEK. Current guess is moisture accumulating somewhere
Six Euro Deliveries since December 1998 (Owned E46, E90, E91, E92 and E93)
28 vehicles in 26 years of driving so far. Guess I like cars
Old 12-09-2012, 09:59 AM
Try cleaning your icv and maf
Old 12-09-2012, 10:06 AM
Oh wait,..., nvm about that!
Old 12-22-2012, 01:09 PM
Pulled the codes... got nothing... No errors have been logged...
//Brew
Old 12-23-2012, 08:10 PM
mike in texas's Avatar
mike in texas mike in texas is offline
Mike in Texas
Mein Auto: 2007 328i coupe
your comment about moisture makes sense because the last time I had this issue is after I washed my car with a power washer.
Have you learned anything new about his issue.
07 - 328i Coupe
Old 12-24-2012, 06:23 AM
MiT: No I haven't.... I'm wondering if the battery may be starting to fail? It's still original and I know some days (cold days) it seems to struggle ever so slightly when starting the car...
My driving "pattern" is roughly 2 long (500+ mile) trips per month with a majority of that non-stop giving the battery a good long charge each month... But still, it could finally be starting to show it's age and generating some odd gremlins.
//Brew
Old 12-29-2012, 03:54 AM
MP3_E46's Avatar
Code/wrench Monkey
As mentioned above the root cause could one or a combination of many factors. A new battery resolved the same issue in my low mileage car though
Old 12-29-2012, 06:22 AM
Your last walnut shell blast was....was....when?
Old 12-29-2012, 06:23 AM
MP3_E46's Avatar
Code/wrench Monkey
He has a 328i; a few doses of techron 'should' suffice
Old 12-29-2012, 06:31 AM
Did that read "walnut shell blast?"
Frequently a victim of random hand spasms, I mis-posted. Shoulda read: "Vanos solenoid blast [air]."
Name:  Disoriented Smiley.jpg
Old 12-29-2012, 08:26 AM
MP3_E46's Avatar
Code/wrench Monkey
Was in a pinch at work yesterday and bought a can of compressed air from WalMart.. would have been so much more fun to bring in my Pancake Compressor and use that like I do at home
Old 12-29-2012, 11:52 AM
bluskye bluskye is offline
Mein Auto: 2006 330i / 2007 X3
I've had issues with faulty IBS (Intelligent Battery Sensor) and low battery in the past, both very bizarre.
IBS failure: RPMs would drop dramatically during cruising as if the car lost electrical. Codes would read faulty Water Pump and IBS in this condition. The faulty water pump code was triggered because it lost electrical power (electric pump). Dealer replaced IBS and all is resolved.
Low battery - the bastard issue to nail down: Subtle rpm dips at idle/cold. HVAC fan would go in and out in really cold or really hot conditions. Yes, HVAC fan. I replaced fan/resistor thinking they were busted, but that was not the problem. Resolved with a new battery, in my case, Interstate Megatron Plus. These issues were resolved by mistake as I normally swap out batteries every 5 years or so I dont get stuck out in the cold.
These cars are dam sensitive to electrical glitches.
Old 12-29-2012, 05:11 PM
MP3_E46's Avatar
Code/wrench Monkey
Ouch, your pain is felt!
So the conclusion is if your battery is at least three years old and these symptoms appear swap the battery out first. Cheap-ish easy DIY (~$100 from Walmart) that would need doing sooner or later anyway
Old 12-30-2012, 06:07 AM
lol... ah never...
//Brew
Old 12-30-2012, 06:10 AM
Attachment 355041
Ahhh now THAT I have had done.. It was at 59,200 on the odo.
//Brew
Old 12-30-2012, 06:33 AM
OD's now 114K - time for another dose.
Inexpensive multimeter reads battery voltage after lights on awhile.....<12 volts?
YO! If you got that guy's problem, assault your battery, an inconvenient R&R in the German tradition.
Bavarian Technic scan tool will enable you to register your battery. Among many, many other things....GET ONE.
I LOVE the smell of a DIY on a frosty December morn....
Old 12-30-2012, 07:33 AM
MP3_E46's Avatar
Code/wrench Monkey
OD's now 114K - time for another [URL="http://www.e90post.com/forums/showthread.php?t=486201&highlight=VANOS+solenoid+DIY"]Inexpensive multimeter reads battery voltage after lights on awhile.....<12 volts?
Good point. I did that with mine and it read low. Exact number is probably in a previous thread. Seems a sensible way to detect batteries like that mine that would charge to the correct voltage but not hold it for long
Ah, found it in the email to a local SA: it measured 11.7 V and indeed needed replacement
