Old 12-06-2012, 07:58 AM
Dnormand Dnormand is offline
Mein Auto: 01 525i
Oil Separator Small Vacuum Hose
I purchased a CCV kit for my 2001 BMW 525i. Installing it, for a moderately experienced DIYer, was a bit frustrating. I was able to find 3 video segments on Youtube that did a good job of providing step by step (look up M54 Crankcase ventilation). I have 2 issues for the forum - one a question and the other a comment/suggestion.
Question:
The new oil separator(OS) has a small port that was unplugged upon receiving it. Official BMW records say that port is "required" for my model year car. My old OS is not have it so I am thinking just plug it up. What should I do and if needed where does it bloody connect to?
Comment:
In order to connect the breather hose (valve cover to OS) I used a heat gun to soften the OS side due to it being very stiff. I actually broke the first OS trying to connect this one. (urrrrgggg!) Sometimes these aftermarket kits require a little finagling right?
Responses appreciated. Here is what I am talking about.
Old 12-06-2012, 08:09 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
This thread, found by typing /ccv F3 in the bestlinks, was designed to answer your question well before you asked it:
- Clarification on how the M54 CCV vacuum port works on the M52 CCV valve connection to the fuel pressure regulator connection (1)
If it doesn't answer your question - please ask over there as that's the canonical thread for the CCV vacuum port connection.
Old 12-06-2012, 09:29 AM
Fudman's Avatar
Fudman Fudman is offline
Question:
Comment:
[/IMG]
+1, per BBs response, as you have the M54, the port should be plugged. I am surprised you got a CCV that was missing the plug.
Are you referring to the vent pipe or the connecting pipe. The vent pipe (which connects to the VC) simply requires that you push it on until it clicks. However, the connecting pipe (which connects to the intake manifold) is a PITA to install. It requires rotating the pipe to connect. Refer to step 12 of my DIY for my workaround to getting this pipe installed.
http://www.bimmerfest.com/forums/sho...240&highlight=
Old 12-06-2012, 10:33 AM
Jason5driver's Avatar
Jason5driver Jason5driver is offline
Mein Auto: E39 hamster w/ pin-wheel
Question:
Comment:
#6 in the diagram is plugged in the newer I6 face-lifted E39 models (525i, and 530i).
The vacuum hose at #6 is ONLY used on the older I6 E39 models, (ex. 528i's).
Save your money and just get the Cold Weather CCV version as a kit, and buy the (2) additional hoses needed.
You should also buy the New Oil dipstick tube as well...
Link to different parts...
http://www.ecstuning.com/BMW-E39-525...Oil_Separator/
Link to my thread:
http://forums.bimmerforums.com/forum....php?t=1376457
Link to Cold Weather CCV kit at E-BMW-Parts.com (BMW Dealer in Peabody, Mass. - best price I have found for the kit):
http://ebmwparts.com/parts/index.cfm...&siteid=216397
Another great place to purchase parts (another BMW dealer, but in Ohio):
http://www.thebmwpartstore.com/
Originally Posted by Mark@EAC View Post
Ok now check this out.
http://bmwfans***91;/img] ******** LINK B...oil_separator/
You can see now that the "kit" is made up of numbers 1,2 and 3.
To complete the "kit" to include all insulated hoses you would need:
11 61 7 532 629 Vent hose (insulated)
11 61 7 504 536 Return Pipe (insulated)
which are numbers 4 and 7 in the diagram I posted above.
If memory serves me correctly you do not need part 6 on a 5 series.
That does not apply to the e39 and there is no place to plug it into the CCV.
Thanks guys!
Old 12-06-2012, 11:05 AM
Mein Auto: 01 525i
Thank you
It turns out that thanks to Bluebee I do not need to attach hose #6 on my M54. Has anyone tried to install this on the M54 and found the valve cover breather hose #2 to be stiff and impossible to install? Thanks all for comments.
Old 12-06-2012, 11:15 AM
bluebee's Avatar
Good point!
I think there are three options for the lousy oil dipstick:
1. New redesigned dipstick
2. Modify existing dipstick
3. At least clean existing dipstick
Details here:
- How to test, clean, & redesign the original BMW dipstick guide tube to prevent CCV vent clogs (1)
Old 12-06-2012, 02:18 PM
Steve530 Steve530 is offline
Mein Auto: 2001 530i
Originally Posted by Fudman View Post
+1, per BBs response, as you have the M54, the port should be plugged. I am surprised you got a CCV that was missing the plug....
Bought my CCV at the dealer and it came without a vacuum cap on that port.
Steve
2001 530i/5 S+P CDV delete/Akebono ceramic pads
M5 SSK/RedLine MTL/M5 rear sway bar/Bilstein HD
OSRAM CBI
BMWCCA Member #337964
Old 12-06-2012, 04:54 PM
bluebee's Avatar
I guess they expect you to swap the old vacuum cap to the new CCV.
However, given that the old one is a decade old, and, that it's not at all easy to get to after the fact, I would recommend the OP buy a new one.
Problem is that they're metric (ask me how I know), so, you probably want to go to the stealer to get it as the auto parts stores near me didn't carry metric sizes.
Old 12-07-2012, 06:27 PM
aspensilver540 aspensilver540 is offline
Mein Auto: 1997 540i
Wow, very nice diagrams bluebee. I only wish you I6 engineers would do a diagram for the V8
Old 12-10-2012, 09:01 AM
Mein Auto: 01 525i
20% Reduction in Gas Mileage!! WTF!
After completing the CCV kit replacement my rough idling issues went away but I am seeing a reduction in gas mileage from 22 to 18. Has anyone seen this before?
Old 12-10-2012, 09:53 AM
manticore33's Avatar
manticore33 manticore33 is offline
Send a message via AIM to manticore33
Mein Auto: '86 Porsche 951, '01 530i
Bluebee, nice modification to the dipstick tube.
How many people encounter the snotty oil build up? The reason I ask, I live in a colder climate (Central Ohio), my car is from Pittsburgh, and the original non-cold weather CCV was "snot free" and the double-walled dipstick tube was clear @ 212k. The car is driven all year and sits outside...
I like coffee.
My e39 is fixed and moving towards atrophy.
