Old 12-06-2012, 09:19 AM
gulshan gulshan is offline
Mein Auto: e92-n54
help with n54 walnut blaster service info
I have a 2007 e92-n54, 6MT (zhp,zpp) with about 32k miles. I plan to keep the car for another 5-6 years at least). I am a DD and do not track or heel toe and all that stuff. I do not granny the car either. Occasionally drive hard. I plan to follow good old Mike Miller maintenance. From a maintenance perspective when do you guys do the walnut blaster service for a n54 ? (at what mileage or after how many years ? ) Mark does not talk about this in his guide or maybe he uses a different term for this. Apparently you need a special tool to do this and not all Indy shops do it. Costs about $500 i think at the dealer. thanks
Old 12-06-2012, 09:53 AM
KAP8's Avatar
KAP8 KAP8 is offline
Mein Auto: Alpinweiss F32
I had never heard of a "Walnut Blaster" service until now. I found this thread, and the guy seems very happy with the results.
http://www.bimmerboost.com/showthrea...-*pics-inside*
2015 435i ///M Sport | Alpine White | Coral Red | 19" | Auto | Cold Weather | Driver Assistance | Dynamic Handling | Lighting | Premium | Technology | M-Sport Brakes | Rear Sunshade | HK | Leather Dashboard | MPPK | MPE | Dinan Suspension | BMWCCA #409820
PCD: 10/31/2014
Old 12-06-2012, 10:06 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
60k mi is the rule o'thumb.
DIY
$600 dealer service.
Best: Use boroscope to evaluate; do when needed.
Old 12-06-2012, 10:28 AM
KAP8's Avatar
DIY
I'm at 64k. I may consideer having my Walnuts Blasted. They certainly look brand new once they are clean. I'm really surprised that I haven't read about that process before.
PCD: 10/31/2014
Old 12-06-2012, 10:49 AM
Mein Auto: e92-n54
DIY
Thanks CALWATERBOY
Old 12-06-2012, 10:50 AM
Mein Auto: e92-n54
great link. Never saw this when i googled. thx
Old 12-06-2012, 12:16 PM
Leekay07 Leekay07 is offline
Mein Auto: X5 35D, Former X1 and 335
I just did mine yesterday. What a pain by hand but my car is back now. before it would misfire when I put my car in 5th at 35mph and then press the gas to about 75% and let it pull to 70mph.
If you like customer service. Don't look beyond a BMW.
Old 12-06-2012, 04:23 PM
fun2drive's Avatar
BMWCCA 149159
I'm at 54K miles and most of that is hiway. I have a borescope and plan to check this out in a few months. I do plan to go to 70K miles if the intake valves look good. Otherwise I will pull the intake and do the walnut blasting. This has been around for over 2 years now and is caused by oil vapor blow by under both vacuum and boost from the PCV. BMWs version leaks some and there is another source of a better valve that has been produced but works only for boost. Under vacuum the oil vapor still gets by. I don't know how much gets by under vacuum and I hope to be able to take some pics with my borescope to see how bad it looks. I have not run the piss out of my 335, that is what my M3 is for so I don't know how typical I would be as a driver.
RBturbo.com is the person supplying an alternative. I bought one and will install it when I do the intake valves...
