X5 E70 (2007 - current)
Talk about the latest generation X5, codenamed E70, with other BMW owners here. |
BMW X5 Starting Problems - 4 mechanic's later HELP!
Hello all hoping I can find some ideas here as to what may be causing my issue.
I'll try to keep this as concise as possible... 2007 BMW X5 3.0si Problem: Car cranks but will not turn over in cool cold or rainy weather. After trying a few times sometimes 1-2, sometimes 9-10, the car will finally start. A couple times I've had it completely not start at all. What's been inspected (as far as I know): Fuel pump Starter Battery Fuel pump wiring kit Issues found and resolved: 2nd mechanic pulled codes for crank and cam sensor, both replaced with original BMW parts. Last mechanic pulled the dash and found oil filling the computer module casing. Cleaned that out. My main issue is that whenever it's at the mechanic they have a tough time finding out exactly what it is because the car will eventually start. Does ANYONE have ANY recommendations/possible solutions?? Thanks so much for any help or advice. |
I remember the old days when camp weather could stop a car dead in it's tracks. The issues were almost always related to the ignition system. Not certain what you mean by "oil filling the computer module casing" as I have no idea what or where that might be but if it controls the ignition, it's probably the 1st place to start, right?
Obviously, just "emptying" something would not be sufficient as it would simply "fill up" again later, right? so what did they do to prevent that from occurring again? Sealed a connection? Replaced a component, etc? Why not simply take it to a BMW dealer rather than all the (obviously) pointless attempts with independent shops that obviously don't know how to properly diagnose it?
![]() '12 X5d Sapphire/Black/Bamboo, Sport (ZAP), Premium (ZPP) & Premium Sound(ZPS) packages: 20" 214's, OEM Hitch![]() GONE - '06 750Li Sapphire Black/Creme&Black (Loadeddddd)
I took it to the BMW dealership 1st foremost, and they told me to come pick it up because they can't diagnose when the car starts. As I said it usually eventually starts. Anyone have any ideas? Thanks. |
Not sure if you got your issue resolved, but I experienced something very similar this week in our 2007 X5 4.8. Drove fine all day, went to a wedding, came outside an hour later and it wouldn't start. Would turn over, but wouldn't crank, like it was starved for fuel. Outside temp was about 40 degrees. I suspected the fuel pump. Returned the next day, a little warmer, and it fired right up.
Took it to the shop and they thought it was the fuel pump or the cam sensor. However, they couldn't replicate the problem and there were no real fault codes. They checked the pump and all the pressures were normal. There suspicion was the sensor, but suggested that we hold off on spending the money to replace as that might not resolve it. Got it back and the same night we encountered the problem again. If finally cranked on the 5th or 6th try, so we took it back to the shop. The next morning it would turn over, but wouldn't crank. They tested the pump again, and this time the pressure was no good, so it was the fuel pump after all.
2002 525i (retired) 2005 545i (retired) 2007 X5 4.8i (wife's car) |
