Old 12-07-2012, 12:05 AM
Fuzzykb001 Fuzzykb001 is offline
Mein Auto: 528i
Spark plugs
Ok just need some advice?
Hmm platinum + 2 or platinum +4 or ???
Which is better for my 98 528i , I want to do a basic tune up. Also want advice about
Coils to go with the plugs?
Old 12-07-2012, 12:19 AM
Polikarpov Polikarpov is offline
Mein Auto: BMW 730i, seeking 325 e30
BMW engineer's recommends Bosch F7LDCR. This is original.
Old 12-07-2012, 04:56 AM
JimLev JimLev is offline
Mein Auto: 540/6, S60 Volvo, Tribeca
You don't need coils unless they are defective, in which case you would be getting a check engine light.
2000 540/6 Slightly tweeked...everywhere
Old 12-07-2012, 06:27 AM
poolman poolman is offline
Mein Auto: 525i station wagon
Go with the NKG Iriduims for plugs and there are others about that will give the same advice--these plugs are the stuff
Old 12-07-2012, 06:40 AM
matt540's Avatar
matt540 matt540 is offline
Mein Auto: DINAN 540
+1
Dinan F&R strut tower brace, M5 F&R sway bars, Koni Sports, Eibach springs, Dinan stage 1 engine and trans software, Zionsville cooling kit, resonator delete, Dinan exhaust, AFE cai, 18' style 5's, 235/40/18 275/35/18, and some small cosmetics, with more to come.
Old 12-07-2012, 07:35 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
This has been discussed many times so I simply point the OP to one of the discussions:
- What is the best plug to use in the BMW E39 (1) (2)
If the user wants a DIY, I point to this highly pictorial DIY that is easy to follow:
- One user's pictorial DIY for replacing the BMW M54 engine spark plugs (1)
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders.
See also: E39 Bestlinks & How to easily find what you need, in seconds!
Old 12-07-2012, 08:44 AM
Mein Auto: 528i
Let me give a few more details bought this car as adaily driver . Love the 18-20 city/ 27-34 hwy average in my first 1000 miles.
1998 528i base,
153k on clock
Have no idea when last service
Just did Lof service. 5/30w royal purple syn. Oil
Changed some nasty air filters-cabin & engine.
Just figuring it would be good place to start at the 150k service recomended by book.
Coils & plugs recommened hince my looking for advice.
Also trying to get major systems checked for posssible problems coming up
Old 12-07-2012, 09:30 AM
bluebee's Avatar
Typing /maintenance F3 in the bestlinks nets a whole bunch of printable service checks you should make.
- A BMW CPO PPI inspection checklist (1) (2) & an official BMW CPO retailer operations manual (1) (2) & a BMW certified preowned pre purchase inspection brochure (1) (2) (3) & a BMW service/maintenance schedule & checklists I, II, and III (1) (2) (3) (4) (5) & a classic E39 inspection I, II, III DIY (1) (2) (3) & tips for BMW E39 150K mile maintenance issues (1) (2) (3) (4) (5) (6) (7) & a glovebox printout for the most often recommended BMW E39 fluids (1).
Just pick one of those, for example:
- BMW_realistic_maintenance_schedule_2009.pdf
Old 12-07-2012, 11:26 AM
AnotherGeezer's Avatar
AnotherGeezer AnotherGeezer is offline
Hofmeister Kink
Mein Auto: 2003 530i/5
My I also recommend a fresh set of these
Yours, if they have never been replaced, are probably overdue.
BMWCCA # 430911
Old 12-07-2012, 02:50 PM
540 M-Sport's Avatar
Mein Auto: 01' 540 M-Sport cdn, F355
+1, if over 100k miles, it is good preventive maintenance to replace the spark plug boots. I have seen enough posts about failures after that point to figure it is worthwhile to avoid problems in the future.
Factory M-Sport with factory installed M-tech bumpers, factory Bluetooth, factory M-Audio 10" dual voice coil subs, homelink, M5 rear stabilizer bar, Bilstein B14 PSS coil overs, stop tech ss brake lines, Akebono Euro Ceramic brake pads, oem Brembo and Zimmerman rotors, Dinan Stage 1 software, strong strut front upper stress bar.
Old 12-07-2012, 06:01 PM
aspensilver540 aspensilver540 is offline
Mein Auto: 1997 540i
Any more details? I see boots reccomended a lot on the benz board but not much here, and they are pretty cheap. Did you fix a specific issue or see any kind of improvement?
Old 12-07-2012, 07:35 PM
FLE39 FLE39 is offline
Mein Auto: 2003 530i 5spd Manual
I did my plugs at 94k and the boots were in great shape. Plugs had never been done. on a Coil on plug application like we have I've had good results with putting di-electric grease on the boots; inside and out. Nice coating all over the outside and put a small squirt into the boot for it going on the plug. Next time it's much easier and it keeps moisture out. Extends the life of the boot tremendously too. Just my 2 cents.
As for plugs. You have 3 to choose from the way I see it.
1- OE NGK plugs (What I did due to they will last a 100k interval, are OE and cheapest option of the list)
2- Irdium NGK .6mm tip Will last about 40-60k
3- Iridium Denso .4mm tip Will last about 40-60K
I steer clear of the Bosch +'s. Never had good results. Nor have I seen them come as OE. If I use a Bosch, it's the OEM Bosch. Like in my 335i. Very odd plug. Stuck with the OE bosch. I wanted to use a OE Irdium NGK, but they don't make that plug for our car. That would be sweet if they did. That's probably my favorite plug. 100K life and iridium. And it DOES come as an OE plug in a ton of cars. even the corollas have them OE, Lexus, ETC. One of the best overall plugs you can buy IMO. Not sure why they don't have a listing for it on the 530i.
DD: 2003 530i 5spd manual sport package. Conti DWS's, Llumar ATR, White LED lighting. TLC on-going.
Garage queen: '07 335i Sedan, base pkg, 6spd Manual, Procede 3 V5 w/NLS, staggered 18" 313's w/Conti DWS's, HKS Exhaust, OS Giken TCD LSD, VAC Street Diff Cover, Akebono Euro Pads, CDV Removed, Black BMW Grilles, Interior & Exterior white LED lighting, LUX Angel Eyes, Debadged, Llumar ATR Tint.
