Old 12-07-2012, 05:54 AM
mike turnage mike turnage is offline
Mein Auto: 745i
key fob
niether of my key fobs are not working can anyone help?
Old 01-17-2013, 05:44 AM
John Kingsbury John Kingsbury is offline
Mein Auto: 730 D SE --- 2006 E65
Have opened them up and changed the battery's ?
Old 01-17-2013, 05:51 AM
Mein Auto: 745i
its sealed and cant open it without breaking it
Old 01-17-2013, 05:59 AM
What model of BMW, does the key fob plug into the dash? As they should recharge when plugged in.
It would be a bit strange for them not to come apart to allow battery change?
Old 01-17-2013, 06:08 AM
Mein Auto: 745i
2003 745i
Old 01-17-2013, 07:00 AM
http://www.ehow.com/how_6245682_open...6-key-fob.html
Try this link
Old 01-17-2013, 07:05 AM
Mein Auto: 745i
ok thanks i will
Old 01-20-2013, 12:12 PM
bayerisheteknik bayerisheteknik is offline
Mein Auto: e65
try tapping(finger flick) on the fob itself while holding it in hand...sometimes that helps and it works...your batt is recharging everytime your car is running so thats why they dont come apart
on mine the unlock wasn't functioning...opened it up and microswitch was broken off...had to re-soldered it back on the board and voi'la
Image and video hosting by TinyPic
and there is microswitch that broken off
Old 01-21-2013, 04:08 AM
Entamean Entamean is offline
Mein Auto: 2006 BMW 750i
I have an 06 750i. the key fob was working fine. now sometimes it does and others it doesn't. Could it be the battery and if so, can it be replaced ?!
Old 02-16-2013, 11:18 AM
It's probably the button, do you get a low battery warning when you plug the key into the car?
Old 02-16-2013, 11:20 AM
Entamean
If you search on google how to fix BMW 7 keyfob it will show you what you need to solder to repair the fob
Old 02-17-2013, 03:11 AM
Thank you. I will try that. Actually, now when it does it, I tap it with my finger hard and it works. ?!?!
