7 Series - E65 / E66 (2002 - 2008)
Discussion pertaining to the flagship BMW here. |
Oil Pressure Sender
Hey guys, I have an oil leak on the pass side. and I am sure it's the vacuum pump needing to be replaced but that will have to wait a week or two, and it's not a bad leak.. but I would like to replace my oil pressure sender too as it may be leaking and I already have a brand new one.. I read somewhere on here someone used a deep 24? and an extension? I can't find it again, but do I have to remove the air box and or anything else to get to it?
Thanks! |
![]() 2001 X5 3.0i 200k miles & counting...( SOLD) Dinan Stage 1 Trans and Engine /SMG M3 Steering wheel/M5 SMG shifter/BMW rear entertainment/4.6IS body kit/4.8is Exhaust/ X-pipe/Turner HP Pulleys/E92 sport seats/Group M Intake/Brembo drilled rotors/Quart projector beams headlights 06 750Li with 19k miles. Bone stock. |
It was me, to remove the original Oil pressure switch, i used a deep socket 24 and an extension, whole air box (top an d bottom) prolly should move the MAF and elbow also.
the new switch i had fit the o2 sensor socket i had and an extension. its easy. http://www.bimmerfest.com/forums/sho...86&postcount=1
06 X5 3.0 Toledo Blue Metallic/Light Beige 2: Adaptive Xenon Headlamps, Panoramic Sunroof, Rear Sunshades, +Factory Aux Input in Ashtray, Bluetooth, Rear PDC Sensors, Rear Electronic Adjustable Seat Backs, +White Angel Eye LEDs, +4300K Foglight HIDs, +Blacked Out Chrome Grill Surround .. more updates to come PREVIOUS 2002 745i |
Thanks, when I did my angel eyes I tried to remove the air box I took out all the bolts, I checked all over, but I could not get it to actually come out. It moved pretty freely but no go.. I ended up putting them in with the box in, which everyone said couldn't be done... it can if you can handle alot of hand pain
did u free the screws on the exp tank and move it over? u need to do that to remove the lower portion of the air filter box.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
