Z3 Fan switch oring? - Bimmerfest - BMW Forums
Old 12-07-2012, 10:52 AM
grecken grecken is offline
Mein Auto: 2000 BMW Z3 2.3
Replacing my radiator and just removed the fan switch and there was no oring. Should there be? The Bently manual says to replace the oring. Thanks
2000 Z3 2.3 with 2.5l motor.
Old 12-07-2012, 12:31 PM
Blacklane Blacklane is offline
Mein Auto: 1998 Z3 Roadster
RealOEM.com shows one. PN 32411093596
They also show the dimensions (A14x20), so you might be able to find one locally.
Old 12-08-2012, 04:28 AM
Thanks for the reply, Blacklane. Realoem shows one on the 2.8 nd 1.9, but not on my specific motor. I was told by an online retailer, that it was not used on my application. So, since it came w/o it from the factory (as far as I know, no one had ever touched it), I went back w/o it. Did not seem to be leaking befote....I'm probably being a little overly concerned about it. Thanks again.
