Old 12-07-2012, 02:48 PM
onsafari onsafari is offline
Mein Auto: 06 330XI
Xenon adaptive headlight issues
Hi....new to the forum here and have a question, search came up with nothing. So the wife has an 06 330XI with the adaptive xenon headlights and the driver side is not working right. When you turn them on they go through their nomal stat up routine but the drivers side is a purple hue vs the white/blue hue it should be. Dealer thinks its the bulb but I'm not wanting to drop $240 for a bulb and it not be the issue...anyone have any experience with this issue?
Old 12-07-2012, 02:56 PM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is offline
Flying monkey herder
Mein Auto: Daihatsu Terrios
thats most likely the bulb. a spent HID bulb will get bluer, then purple, then pink before dying.
you can get a pair of quality bulbs for much less. try ebay for phillips or osram. DO NOT get anything higher K than the stock (4300K).
http://www.ebay.com/itm/Philips-D1S-...f1c44f&vxp=mtr
replace both at the same time-- the other bulb is likely on the way out as well, the output and color will not match if you replace only one.
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Present: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL
