Old 12-07-2012, 10:10 AM
cmpcpro cmpcpro is offline
Mein Auto: Nothing
Oil Pressure Sender
Hey guys, I have an oil leak on the pass side. and I am sure it's the vacuum pump needing to be replaced but that will have to wait a week or two, and it's not a bad leak.. but I would like to replace my oil pressure sender too as it may be leaking and I already have a brand new one.. I read somewhere on here someone used a deep 24? and an extension? I can't find it again, but do I have to remove the air box and or anything else to get to it?
Thanks!
Old 12-07-2012, 11:46 AM
mrbmwx5 mrbmwx5 is online now
Mein Auto: 06 750Li
http://tis.spaghetticoder.org/s/view.pl?1/07/45/86
2001 X5 3.0i 200k miles & counting...( SOLD)
Dinan Stage 1 Trans and Engine /SMG M3 Steering wheel/M5 SMG shifter/BMW rear entertainment/4.6IS body kit/4.8is Exhaust/ X-pipe/Turner HP Pulleys/E92 sport seats/Group M Intake/Brembo drilled rotors/Quart projector beams headlights
06 750Li with 19k miles.
Bone stock.
Old 12-07-2012, 02:55 PM
745iguy's Avatar
745iguy 745iguy is offline
Besessen Deutsch Autos
Mein Auto: 2006 X5 3.0
It was me, to remove the original Oil pressure switch, i used a deep socket 24 and an extension, whole air box (top an d bottom) prolly should move the MAF and elbow also.
the new switch i had fit the o2 sensor socket i had and an extension. its easy.
http://www.bimmerfest.com/forums/sho...86&postcount=1
06 X5 3.0 Toledo Blue Metallic/Light Beige 2:
Adaptive Xenon Headlamps, Panoramic Sunroof, Rear Sunshades,
+Factory Aux Input in Ashtray, Bluetooth, Rear PDC Sensors, Rear Electronic Adjustable Seat Backs,
+White Angel Eye LEDs, +4300K Foglight HIDs, +Blacked Out Chrome Grill Surround
.. more updates to come
PREVIOUS 2002 745i
Old 12-07-2012, 07:03 PM
Mein Auto: Nothing
Thanks, when I did my angel eyes I tried to remove the air box I took out all the bolts, I checked all over, but I could not get it to actually come out. It moved pretty freely but no go.. I ended up putting them in with the box in, which everyone said couldn't be done... it can if you can handle alot of hand pain
Old 12-07-2012, 07:14 PM
745iguy's Avatar
did u free the screws on the exp tank and move it over? u need to do that to remove the lower portion of the air filter box.
PREVIOUS 2002 745i
