Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > General BMW Questions
Use this forum to ask general question about the BMW ownership and keep up on the latest BMW news. Direct all model specific questions to model specific forums below.
Old 12-08-2012, 10:29 AM
thesosman thesosman is offline
Mein Auto: 2013 BMW X3
IDrive and Iphone Music
I put this under General because I believe all the BMW iDrive systems work pretty much alike. I have a 2013 X3 with iDrive, an iPhone 4s (64GB with BMW Apps), and a iPhone Snap-In Adapater in the center console. I have loaded all my iTunes music onto my iPhone and that works fine. When I plug my iPhone into the adapter I can play all the music just fine and run the BMW Apps. I was under the impression from the Owner's Manual (Navigaton,Entertainment,Communications) that all the songs would be uploaded onto the BMW's Hard Drive, and then I could play them without the iPhone plugged in. They do not seem to upload from the adapter. (In fact the manual says it will upload if I connect a USB device via the USB audio interface. Does anybody have thoughts on what I am doing wrong and what I could do to get the songs to upload?? Thanx
Old 12-08-2012, 11:42 AM
SD ///M4's Avatar
SD ///M4 SD ///M4 is offline
(prev. SD335is & SDZ4MR)
Mein Auto: 2016 M4 Coupe | 2006 Z4MR
Originally Posted by thesosman View Post
I put this under General because I believe all the BMW IDrive systems work pretty much alike. I have a 2013 X3 with IDrive, an Iphone 4s, and a Iphone Snap-In Adapater in the center console. I have loaded all my Itunes music onto my Iphone and that works fine. When I plug my Iphone into the adapter I can play all the music just fine. I was under the impression from the Owner's Manual (Navigaton,Entertainment,Communications) that all the songs would be uploaded onto the BMW's Hard Drive, and then I could play them without the Iphone plugged in. They do not seem to upload from the adapter. (In fact the manual says it will upload if I connect a USB device via the USB audio interface. Does anybody have thoughts on what I am doing wrong and what I could do to get the songs to upload?? Thanx
You cannot upload the music from your iDevice to the hard drive on your BMW. I can't speak about the 2013 X3 but on the 2011 E92 there is a USB port inside the glove box on the left side solely for loading music onto the hard drive from a USB drive (not an MP3 device).
While you think these system all work pretty much the same, you'd probably get a better and more accurate response if you post in the X3 forum. I would also read your owner's manual again more carefully.
P.S. It's "iDrive" and "iPhone". Companies pay pretty close attention to their branding and these products are specifically spelled this way for a reason.
- Tom
His: 2016 M4 Coupe | Sakhir Orange Metallic | Black Full Merino Leather | CF Trim | M DCT | Adaptive M Suspension | 19" Black Alloy Wheels | ZEC | ZLP | ZDB | MPE | ED 5/13/16
Hers: 2011 335is Couipe | Le Mans Blue Metallic | Black Dakota Leather | Dark Glacier Aluminum | 6MT | ED 5/12/11
Also His: 2006 Z4 Roadster (E85) | Interlagos Blue Metallic | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12
idrive iphone music
