E46 (1999 - 2006)
Old 12-08-2012, 05:11 AM
Major2014 Major2014 is offline
Mein Auto: 318i E46
E46 2003 drivers door wil not manually lock or unlock
The drivers door on my E46 will not lock or unlock with the key manually inserted. It feels like the key/lock is not connected to anything.
The beeper key works to lock and unlock the car, however on occassion it fails and I have to manually unlock the car.
Does any one know what the problem is with the door lock?
Major 2014
Old 12-08-2012, 07:03 AM
jvr826's Avatar
jvr826 jvr826 is offline
Is it Trackday yet?
Mein Auto: 05 330ci 6MT
There is a physical connection between the lock cylinder and the electronic actuator which is easy to check without removing the door panel. I'd start there...
Here's a great thread on the topic:
http://www.bmwenthusiasts.co.uk/foru...php?f=55&t=941
To remove the key mechanism from the door is quite easy. There is a black rubberized covering inside the door (striker side) that hides an access hole to the retaining screw. This image from a Fanatics thread shows how to access it:
Jeff R.
