Just got a '99 323i. Airbag question. 5 airbags are deployed... - Bimmerfest - BMW Forums
E46 (1999 - 2006)
Old 11-20-2012, 11:44 AM
Aureliaz3 Aureliaz3 is offline
Mein Auto: 1998 740iL
Arrow Just got a '99 323i. Airbag question. 5 airbags are deployed...
I am going to replace all the airbags. I was told that the airbag crash sensors either need to be replaced or recoded. How can I get them recoded? Is there anything else I need to know to fix the airbags? I was considering just leaving the airbags out except the drivers, but i kinda want the car to be correct. Thanks, Joe
Old 11-20-2012, 01:39 PM
MalibuMafiaV's Avatar
TheMalibuMafia
Mein Auto: E60 M5 & ST 335i
Your original airbags should still be fine as long as they've never deployed before. Don't replace them. If they've already been replaced and just need to be coded that can be done by some one who has a air bag tool.
"Be yourself for who you are, or be no one at all" - MalibuMafiaV
TheMalibuMafia.com
BMW 2006 M5 - REALLY LOUD
BMW 2007 335i. Single Turbo 6266.
Audi S4 2000 Stage 3 - Dat turbo spool - SOLD
BMW 2000 3-series - Supercharged Because race car SOLD
Maserati 2004 M128 GT - HREs/tint/straight piped SOLD
BMW 2006 M3 - stock - SOLD
Old 11-20-2012, 02:57 PM
Jimmys 530i Jimmys 530i is offline
Mein Auto: 2003 530i
If you had airbag deployment, the crash sensors do not need to be replaced, just install the new airbags and clear the SRS light. If this is the third time airbag deployment occured, then the SRS module needs to be rebuilt or replaced. Make sure to change the battery safety terminal, don't cheat by soldering a resistor in it.
2004 BMW 330ci Silvergray Sport Package, Cold Package, Xenon Headlamps, Premium Package, 6 Speed Manual, Build Date 9/03
Sold - 2003 325i Sedan Japanrot 5 Speed 8k Xenon Headlamps Build Date 11/02
Old 11-20-2012, 03:11 PM
TheMalibuMafia
soldering resistors with safety features probbaly not the best of ideas if you use common sense.
TheMalibuMafia.com
Old 11-21-2012, 06:24 PM
I have seen it happen. Many people are too lazy to replace the cable, so they will solder in a resistor. Common sense isn't so common, at work today I saw a 2010 528i that had a collapsed frame rail from a 15 mph collision. The aluminum frame rail was damaged previously, and it was heated and beat back into position.
Old 12-11-2012, 06:37 PM
stevenj's Avatar
stevenj stevenj is offline
DIY Enthusiast
Mein Auto: 1999 323i ZSP
can you reset the airbag light with the peake tool? or does it have to be done another way with a special tool?
I have a 99 323i and both front airbags deployed but the side airbags did not.... silly because it was a rear quarter panel collision. I've changed the window regulators in every door, so i know the front doors DO have the airbags in and intact.. any reason they didn't deploy?
Old 12-12-2012, 12:27 PM
I went to the bestlinks thread and typed /airbag to find this for you in a split second:
- What is the cheapest usable BMW airbag srs reset/scan tool on the net (1) & a cn90 DIY for replacing the driver seat belt buckle pretensioner and the passenger seat emulator (1) & what can cause a BMW SRS airbag light (1) (2) (3) (4) (5) (6) & what scan tools reset the fault (1) (2) (3) (4) (5) & what happens when we disconnect the airbag before the battery or we connect the battery before disconnecting the airbag in seat and window regulator repairs (1) (2) (3) (4) (5) (6) (7) (8) & where to obtain an airbag occupancy sensor bypass unit (1) (2).
