E46 (1999 - 2006)
Old 12-08-2012, 11:19 AM
kshade40 kshade40 is offline
Mein Auto: 1999 bmw 323i
Mixing two brand of coolant??
Do bmw need bmw coolant? Also bmw dealership put coolant in but the light came on, so an Indy dealer said it had a small leaks and added a universal coolant....but is it bad that it isn't the same stuff?!
Old 12-08-2012, 11:42 AM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
I think a MORE important issue for you is:
Your car is now 14 years old....has the (entire) cooling system ever been rebuilt ? I`m talking about expansion tank, radiator, water pump, T-stat, hoses, etc.
The road goes ever onward....
(R.I.P. Jever)
*Please support the Wounded Warrior Project*
Old 12-08-2012, 11:43 AM
I have no idea, I'm 17 I don't know a lot about it. I know a lot of hoses were replaced and the dealership said a new radiator was not necessary
Old 12-08-2012, 02:42 PM
jvr826's Avatar
jvr826 jvr826 is offline
Is it Trackday yet?
Mein Auto: 05 330ci 6MT
Welcome... find the WIKI at the top of the page and read it. You'll know a lot more after doing so.
Hoses are not a common failure item, but what are common is: water pump, pulleys, expansion tank, expansion tank cap, thermostat. Every 60-80k miles these items should be replaced as a preventative maintenance measure to save you big buck repairs later.
Search on "oh $hit overheated!" or some combination of those words. Many an engine has been claimed by an overheat event.
Jeff R.
Old 12-08-2012, 09:15 PM
scarede46er scarede46er is offline
Mein Auto: 2001 BMW 325i ZSP
OP, the other people are right. You have more worries than mixing two kinds of coolant at this time.
Old 12-09-2012, 10:46 AM
GoForthFast GoForthFast is offline
Mein Auto: '04 330Ci 6-speed
But it is not recommended to mix coolant types. As you do all else that is suggested after reviewing the advice, drain and get only one coolant type in there. Cheap compared to all else.
Good Luck in learning all about cars.
Old 12-09-2012, 03:01 PM
Around How much would all of that cost???
Old 12-09-2012, 05:30 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Originally Posted by kshade40 View Post
I have no idea,
These cooling system date clues, written to the E39, should apply for the most part to the E46 also:
- Cooling system date stickers & radiator date codes & markings (1) (2)
Exactly. BMW says you can mix brands - but not certain types.
- BMW fluid summary printout for your glovebox (1)
Here's what we have in the BMW E39 glovebox printout for cooling system summaries (which uses the same engine as the E46 so the cooling system threads should apply):
- Coolant, for engine, automatic transmission, power steering, and AC evaporator cooling (1)
See the last line regarding mixing brands versus types (more details in the aforementioned thread).
E39 Engine coolant: phosphate free (for Europe's high-mineral-content water), amine & nitrite/nitrate free (for USA long-life requirements), & low-silicate or silicate free (for Japan requirements) 50:50 mixture of ethylene glycol & water (the Bentleys say distilled water (Bentley 020-11), aka de-mineralized or de-ionized water, some call it purified water, and the BMW AG TIS 12.11.2007 18:56 specifies water with a pH from 6.5 to 8.0, maximum total hardness of 3.6 mmol Ca++/liter, maximum chloride content 100 mg/liter, and maximum sulphate content 100mg/liter; interestingly the BMW TIS says "potable tap water usually fulfills these requirements". EPA reports show San Jose & NYC tap water easily fulfill these requirements. The BMW TIS expressly states additives are not helpful and are not recommended. BMW lists a score of recommended coolants in their BMW AG TIS 12.11.2007 18:55 which meet the BMW N 600 69.0 standard, some of which are BMW PN:81.22.9.407.454 1.5-liter; BMW PN:88.88.6.900.316 1 gallon; Castrol Anti-Freeze NF; BASF Glysantin Protect Plus G48, & Havoline AFC (BD04); but most of which are not easily found in the USA. Many Bimmerfesters recommend BMW coolant; however other Bimmerfesters recommend Prestone Extended Life 5/150, Valvoline Zerex G-05, and Service Pro Universal Formula. Others (e.g., chiefwej, aioros), have tested Evans NPG+ but be aware propanol entails a different maintenance philosophy than the aqueous fluids listed above and is not compatible with them. [Total Volume: 1997 I6=10.5 quarts (2.6 gallons), 1997 V8=12.0 quarts (3.0 gallons), 1998-2002 I6=11.1 quarts (2.8 gallons), 1998-2002 V8=12.7 quarts (3.2 gallons), 1997-2002 V8 with latent heater=13.5 quarts (3.4 gallons)]. Prestone says the only reason for phosphate free is the extremely high mineral content of water in Europe - and that in the USA, it's not needed. Replacement Interval: Every three years (Bentley page 020-9) or every four years (aforementioned BMW AG TIS) starting from date of manufacture (except for M-Power vehicles which have 3-year intervals). Note: Mixing BMW-recommended coolant brands is permissible; but mixing types is not permissible unless it's an emergency.
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders.
See also: E39 Bestlinks & How to easily find what you need, in seconds!
Old 12-11-2012, 11:36 AM
vandyboy vandyboy is offline
Mein Auto: 2001 325i
Putting the universal stuff in with the BMW coolant is okay. Its better than having low coolant by any stretch of the imagination. When you diagnose and fix your leak, replace all the coolant with one kind and stick to it.
As far as your part replacement costs, I have seen cooling refresh kits go from $250 to $450 (without the radiator). Difference in price is based on including the fan clutch and temp sensor. At the very minimum, get the expansion tank & cap, the water pump+gasket and thermostat+gasket. Those will cost you around $175 or so. Stick with the plastic thermostat and housing and make sure the water pump has a metal impeller instead of a plastic one (you will see them listed as such.) Have someone check your top and bottom hoses before you order or buy parts.
If you have a garage put on the parts, expect 2-4 hours of labor, plus supplies (coolant.)
