E36 (1991 - 1999)
Old 12-08-2012, 07:28 PM
E36blownpast E36blownpast is offline
Mein Auto: E36 325i
Question Windows
Ok so originally all the windows and sunroof didn't work so I took the comfort relay and soldered the connection that had poped. Now the sunroof opens but non of the windows still. It's a 1994 325i...also I'v already checked all the fuses so no it's not that and the motors are good I tested them on a friends car....so I'm out of ideas.....any1?
Old 12-08-2012, 07:39 PM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
Whatever the issue was that caused the relay to 'pop' is still present. Check your window switches, and if there is a fuse for the windows also. (I don't recall offhand.) ALso I'd look to make sure the wires running into the doors aren't frayed and shorting out.
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 12-10-2012, 05:38 PM
Mein Auto: E36 325i
Ok so I checked the fuses and theirs only a sunroof fuse and theirs a window lift fuse both of which are good all of the switches are ok except for the driver door...would one switch cause all the windows to stop working...also if so why is the sunroof working because thier all attached to the same relay....only other thing I can think of is theirs a wire grounding out somewhere but again it doesn't make sence since because non of the windows work and after fixing the relay only the sunroof works but I'm no expert....any1?
325i, e36, electrical, repair, windows
