E30 (1982 - 1993)
Old 12-09-2012, 12:13 AM
Chaunceton Chaunceton is offline
Mein Auto: 1989 325i
1989 325i Headlights Replacement
Has anybody found reasonably priced OEM or quality aftermarket headlights for the 325i? I need all four new lights (not just bulbs), and some of the associated mounting parts. And with prices I've been seeing, four new lights will cost me a small fortune.
Old 12-10-2012, 11:57 AM
WickedFast.Inc WickedFast.Inc is offline
Go Fast or Go Home
Mein Auto: 1989 325I
Have you checked pelicanparts.com
Wicked Fast Entertainment
Old 12-10-2012, 02:10 PM
I checked there, but they don't seem to have the classic 3 series style lights. The ellipsoid style? I'm not sure exactly what they're called. Where the center is a bigger type bulb that's darker than the rest of the headlight when it's off.
Old 12-11-2012, 08:57 AM
markseven markseven is offline
an audience of One
Mein Auto: Go Kart with AC
Try the part out threads or visit a salvage yard? Buying brand new Hella ellipsoids will be between $400-500.
Old 12-12-2012, 07:25 AM
BMWFatherFigure's Avatar
Old School
Simple lights are 200 a pair new (Hella). Might need a trick to fit
Current:
E38 Parts Car
Previous:
Old 01-13-2013, 08:58 PM
In case anybody else is looking for ellipsoid low beams, eEuroparts.com is a great source. Watch the sales. The passenger side low beam was $124 and driver's side was $93. $124 is the normal price for all the Hella low beams, and the high beams are $54 each. These are the lowest prices I found.
Old 01-14-2013, 08:17 AM
e30325i e30325i is offline
find a u pull it/junkyard might find a good set
Old 01-14-2013, 12:59 PM
kyfdx's Avatar
kyfdx kyfdx is offline
Who, me?
Mein Auto: 2006 330Ci ZHP
I've basically got this set-up...
http://www.amazon.com/HELLA-00242581...gy_auto_text_y
http://www.amazon.com/HELLA-00285081...gy_auto_text_y
About $200 total from AMAZON (not including bulbs).... It replaces your sealed beam bulb/housing with un-sealed Hella housings, which you can put in H4 and H1 bulbs...
I've still got the sealed beams for the high beams, but plan on converting those as well... it's a nice upgrade..
EDIT: These fit in your existing buckets.... if you need that, too, their may be better solutions..
2006 330Ci ZHP Imola Red
2011 X3 Bluewater
1995 M3 Montreal Blue
1987 325iS Bronzit (retired)
2011 Z4 Space Gray (retired)
2008 X3 Sapphire Black (retired)
2005 330Cic Silver-Gray (retired)
2003 325i Sport Steel Blue (retired)
1967 2000CS Delphin Gray (retired)
