Old 12-17-2012, 02:58 PM
dseidel dseidel is offline
Mein Auto: 750Li 2006
Unlock "Beep" annoyance
Any way to kill the annoying "beep" every time you unlock the car? Is this a code issue?
Old 12-18-2012, 10:25 AM
flash_n flash_n is offline
Mein Auto: 745Li
Yes you can code your key so it doesn't beep. NCS Expert is your friend. Search here or at bmwcoding to see how its done.
Silver 2004 BMW E66 / 745Li (DIYs):
ASK, Logic 7, blower, battery, guibo joint, active stabilizer bar bushings, diff oil, tranny sw update, vacuum pump gasket, window lift, a/c compressor, washer fluid reservoir, belt tensioner and deflector, crankcase vacuum hoses, crankcase vents, solenoid gaskets, headlight overhaul, ISM, hood lifts, driver mirror, sway bar end links, rear fog lamps, headlight washer
next up:
headlight vertical aim, VCGs, P0492
Old 12-18-2012, 01:56 PM
MOPAULY's Avatar
MOPAULY MOPAULY is offline
Mein Auto: Many things
You may even be able to disable this in PROGMAN if I recall. I think you can program the visual and audible.
2007 Kawasaki Ninja ZX-14
2006 BMW 750i
1972 Dodge Charger
1968 Dodge Charger
1967 Austin Healey Sprite
Old 12-18-2012, 02:12 PM
I have a Mac laptop. I'd have to install/run windoz and then download and learn NCS Expert. I'll have the private garage do it...seems to be no way from normal interface.
Old 12-18-2012, 02:17 PM
MOPAULY's Avatar
It's an option you can choose via I drive in the newer 5 series, but in this car it was still left to dealer software.
2006 BMW 750i
1972 Dodge Charger
1968 Dodge Charger
Old 12-18-2012, 03:08 PM
PAPER's Avatar
PAPER PAPER is online now
CRISP & CLEAN
Mein Auto: 745LI
you can turn on or off your audible beep just with your key fob .
I don't remember if it's double tap lock or double tap unlock to
set the audible beep on or off .
If you need a Custom 2013 DVD Navigation Map
East or West for your E65 E66 PM me for price .
Or if you Need an AUX Plug for your car hit me up
