Old 12-09-2012, 10:21 AM
mjalloul11's Avatar
mjalloul11 mjalloul11 is offline
BMW forever
Mein Auto: 1996 528i 1999 MB C240
O2 sensors
I changed my O2 sensors with a used unit because it is hard to find an original NTK one, however i was wondering if the BOSCH sensors of the TU engine would work with the m52 and the ECU would read the signal. I know the wire is short but that can be fixed.
Old 12-09-2012, 11:44 AM
Steve530 Steve530 is offline
Mein Auto: 2001 530i
I don't know what the M52TU used, but I 'm pretty certain that the M52s in the 2008-09 MY used a titania sensor instead of the zirconia sensor used by the M54. I think that the sensors made by NTK used in those models was a titania sensor.
The ECU supplies voltage to the titania sensors, but the zirconia sensors generate a voltage. So they are not interchangeable. The NTK sensors are available, they're just expensive, like $90.
Steve
2001 530i/5 S+P CDV delete/Akebono ceramic pads
M5 SSK/RedLine MTL/M5 rear sway bar/Bilstein HD
OSRAM CBI
BMWCCA Member #337964
Old 12-09-2012, 01:30 PM
mjalloul11's Avatar
BMW forever
Will they produce the same signal for the ECU?
Old 12-09-2012, 01:34 PM
If you're asking if a titania and zirconia sensor produces the same signal for the ECU, the answer is no. They are entirely different sensors.
I do not know what sensor a M52TU uses, so I can't tell you if it works with your M52. I don't even know what years the M52TU was manufactured. I suggest you look at realoem to determine if a M52 and M52TU uses oxygen sensors with the same part number
Steve
OSRAM CBI
Old 12-09-2012, 02:02 PM
mjalloul11's Avatar
BMW forever
what about universal sensors, they are made for all makes and models. does it matter what kind of material it is made of as long as it provides the same voltage as the OE does and at the same rate?
Old 12-09-2012, 02:54 PM
I think the type of sensor you car has does not provide a voltage to the ECU. I think the ECU provides a voltage to the sensor and measures the voltage drop across that sensor. You must use that type of sensor.
AFAIK, universal sensors are really universal fit sensors. That means the wires are not terminated for a specific application. If you can find a universal fit titania sensor, you might be able to use it if you can figure out how to wire it correctly
You might want to look at the wikipedia article on oxygen sensors. That explains the difference in the sensors.
Do you know which NTK sensor your car uses? I mean the NTK part number.
Steve
OSRAM CBI
Old 12-09-2012, 11:51 PM
mjalloul11's Avatar
BMW forever
It is Siemens 5wk9 0231 and NTK 1427884 with the BMW logo on it . And thank you for your feedback
