Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > F10 / F11 (2011 - Current)
The new chapter in the highly successful story of the BMW 5 Series Sedan (F10) and wagon (F11)
Old 12-17-2010, 08:19 AM
coda70 coda70 is offline
Mein Auto: 2011 535i
Erroneous Gas Cap Warning
I'm getting an warning that my gas cap is off but it's not true. Anyone else have that? Gonna take it in...
Old 12-17-2010, 08:30 AM
Needsdecaf's Avatar
Needsdecaf Needsdecaf is offline
Everything's Bigger in TX
Make sure you tighten it completely.
Old 12-17-2010, 09:23 AM
EvolutionTheory's Avatar
EvolutionTheory EvolutionTheory is offline
Mein Auto: 2004 325i
I got this a LOT when I first picked up the 3 series. If you don't tighten it enough it'll sense it's off and I had to take it to the dealership to clear the code.. which cost me $$$. I wasted so much money dealing with that bull**** problem as it would flag my check engine light or something like that so I had to have them check it and reset codes. I could have saved money buying the code reader for $250 at the time and clearing it myself each time.
From my experience so far this is a normal issue. Can you clear it yourself now in idrive or do you have to take it in? I'd recommend getting the tools to check your codes and clear them yourself. Save the money in the long run.
  • Planned: 2012 Space Gray 535i xDrive ///M Sport.
Old 12-17-2010, 09:46 AM
Rafa Rafa is offline
Mein Auto: 2011 550i
I had that problem in my previous E60 528i. The check engine light came on and I took the car to Service. Their diagnostic: a defective gas cap seal. It was replaced and the problem was solved for good.
Fast forward to my F10: gas cap open warning and check engine light comes on. Having experienced this issue before, I tightened the gas cap and make sure that it is tight every time I put gas (which is often in my 550i). The gas cap open warning has not reappeared, but the check engine light is still on. I'll take the car to Service this weekend. No big deal, IMO.
ED on Sep. 28, 2010: 550i Dark Graphite Metallic, Oyster/Black Nappa Leather, Anthracite Wood Trim, Convenience Package, Driver Assistance Package, Premium Package 1 (Std.) & 2, Sport Package, Sport Automatic Transmission, Dynamic Handling Package, Active Cruise Control, Head-Up Display, Side and Top View Cameras, 4-Zone Automatic Climate Control.
Retired: 2008 528i Space Gray.
Old 12-17-2010, 10:02 AM
TJPark01's Avatar
TJPark01 TJPark01 is offline
Mein Auto: F10 535/E92 335i
As mentioned before, it can be a small rubber gasket that is causing the problem and allowing gas cap to not seat properly. Also there is a chance that you could have a leak around the filler tube. Definitely take the car in.
Old 12-17-2010, 10:58 AM
markl53's Avatar
markl53 markl53 is offline
bimmerfest Supporting Member
When I first filled up my new F10 I was surprised that the gas cap did not have the usual "click" mechanism where you continue turning until you get the multiple clicks indicating it's fully tightened. For those who may not know, the F10 now uses a gas cap that basically stops when turned to tighten -- no more multiple clicks. I haven't seen a warning on mine as of yet, but I wonder if this design is more susceptible to air leaks.
BMW-CCA
Bimmerfest Supporting Member
2011 535i AT | Black Sapphire/Cinnamon | Premium | Heated Sts | Nav | Sirius | Anthracite Hdr & Trim
Old 12-17-2010, 05:40 PM
Fixed!
I took it in my dealer and they gave me a new cap and reset the computer. Checked the tires while they were at it. It only took about twenty minutes. It was a very pleasant service experience. BMW rules!
Old 12-17-2010, 05:57 PM
Great! I'll tell the service people when I take my car tomorrow that it should take them 20 minutes to fix this thing. I hope they have a gas cap in stock.
Old 01-19-2013, 08:11 PM
Red Lined Red Lined is offline
Mein Auto: 528, CTS
Looks like I'm having the same problem I need to take the car in for its first service this month. Should I just tell them then and see if they can give me a new fuel cap and reset the computer?
And yes, I tightened the fuel cap...five times...and it came back each time thereafter.
Old 02-04-2013, 01:45 PM
polasrini polasrini is offline
Mein Auto: 2012 BMW 528xi
My dealer said 2012 528xi is recalling for fuel cap software issue and last week I took my car to dealer fix this issue.
