Old 12-09-2012, 07:32 PM
skymast skymast is offline
Mein Auto: 2012 BMW 535
Issue Coding Seat Belt Reminder Chime Removal
I am having an issue removing the seat built reminder in my 2012 535. Specifically, either I don't have or I cant locate the ACSM 3000 Ausstattungsflags SBR_FA_GWF_SBR_BF.
I can find 3000 Ausstattungsflags, 12 but there is not a corresponding SBR_FA_GWF_SBR_BF.
Thx
2012 BMW 535 ... Silver / Black, M Sport, Premium, Premium Sound, Technology, Heated Seats, Sport Automatic
Other Cars ... Mercedes S550, Chevrolet Tahoe LTZ, Porsche 996 Turbo
Old 12-09-2012, 08:46 PM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is online now
Mein Auto: 2011 535i M-Sport
Thx
SBR_BF_GWF_SBR_BF (aka SeatBeltReminder_SBR_Beifahrer)
SBR_FA_GWF_SBR_FA (aka SeatBeltReminder_SBR_Fahrer)
SPW_BF (aka SBR_PreWarning_Beifahrer)
SPW_FA (aka SBR_PreWarning_Fahrer)
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
Old 12-10-2012, 10:07 AM
I am still working through this.
I dont have these ....
SBR_BF_GWF_SBR_BF
SBR_FA_GWF_SBR_FA
So I did try to deactivate these ... but I got an airbag fault code so I reversed and removed the fault code
Show based on other posts, i then deactivated these ...
Initialwarnung_GWF_IW
Gurtzustandsanzeige_Beifahrer_GWF_GZA_BF
Gurtzustandsanzeige_Fahrer_GWF_GZA_FA
However, I am still getting the GONGs.
Any insight?
So, that is all 7 of them.
Old 12-10-2012, 10:20 AM
...So I did try to deactivate these ... but I got an airbag fault code so I reversed and removed the fault code
Any insight?
Yes. Until you set both of these to nicht_aktiv, you will continue to get Gongs:
You should not be getting an airbag fault code. Try it again, and make sure you are changing values in ACSM 3000, and not 3001.
Old 12-10-2012, 11:18 AM
OK. that did the trick. I am wondering if there is a specific order because I did get a fault code when I tried Seatbeltreminder first. Either way, my problem is solved so thank you!
Old 12-10-2012, 12:20 PM
ilhan1103 ilhan1103 is offline
Mein Auto: f30 318d
@Shawn: if you did charge for coding and help on the matter you'd have earned that M6 by now.
Thanks man, seriously
Old 12-10-2012, 01:49 PM
That's okay. Instead, I am moonlighting as a male gigolo for the M6 funds.
Old 12-10-2012, 01:50 PM
Mein Auto: f30 318d
oh crap, there goes my dinner.....
Old 12-10-2012, 02:10 PM
If you kill it first, it won't run away.
Old 12-10-2012, 03:06 PM
Mein Auto: f30 318d
Where's the fun in that you spoiled brat
Old 12-10-2012, 03:10 PM
Eating it.
Old 12-26-2012, 07:43 AM
Travel4Surf's Avatar
Travel4Surf Travel4Surf is offline
Mein Auto: Everglades 243
Anyone know where to find these setting on a f10 with the new 2013 Nav?
Maybe I am just blind....
Old 12-26-2012, 08:18 AM
Yes, a trip to the optometrist may be in order, as the Seatbelt settings are no different in NBT equipped cars.
They are in ACSM 3000, and identical to CIC equipped cars:
For the Seatbelt Staus Displays and Initial Gong, you should disbale these as well:
Old 12-26-2012, 01:14 PM
Thanks Shawn! ...that did the trick.
Old 12-26-2012, 01:15 PM
Old 01-09-2013, 06:01 PM
kazzz kazzz is offline
Mein Auto: X3
If I just want the initial gong removed, which option should I disable? TIA
Old 01-09-2013, 06:02 PM
Old 01-09-2013, 06:14 PM
Mein Auto: X3
Wow !!! Thank you very much.
Old 12-14-2013, 11:13 AM
Deleted
Old 12-14-2013, 11:28 AM
I did some coding on my 2012 about a year ago .... took it jun for service today and they did a software update which wiped all of my changes out. I am trying to make the changes again but when I click read coding data on the CAFD files its saying data not found. Any idea what my issue is? Thx!
Yes. The dealer updated your car's software, now your E-Sys and PSdZData is too old to work with the car.
Old 12-14-2013, 12:12 PM
Thx, what is the easiest way to update this?
Old 12-14-2013, 12:23 PM
PM sent.
Old 11-24-2014, 09:19 AM
unclebnz unclebnz is offline
Redshark
Mein Auto: 650xi Convertible "2015"
I cant seem to turn off seatbelt chime
Old 11-24-2014, 09:23 AM
What car you connect to, and what did you select as your Target Connection?
Old 11-24-2014, 09:28 AM
Redshark
I have a 2015 650XI Conv. I found out what was wrong. The car went to sleep.
New issue: I cant find the code for seatbelt chime to turn off
