E36 (1991 - 1999)
E36 sometimes the acceleration Is very slow almost not moving slow. But after about 3500 rpm the car takes off. And ideals on what to check first. Car idles fine. Starts right up. Thanks.
Fuel?
Plugs? Fuel filter? Air filter? missing? codes? engine? transmission? year? Your post seems a little light on details.
“No cop born isn't a sucker for a finely-executed hispeed Controlled Drift all the way around one of those cloverleaf interchanges. Few people understand the psychology of a traffic cop. A normal speeder will panic and pull over to the side when he sees the big red light and start begging for mercy. This is wrong. Contemptuous to the cop-heart. When running along about a hundred and you find a redflashing CHPtracker on your trail you accelerate.” - Hunter S. Thompson, |
Is it a 318... Because that's just how it is.
Patrick ///98 328i hellrot///BMWCCA#465139 |
1997 328i 2.8 new fuel filter auto transmission with new fluid and filter, sometimes the car runs ok but not very often.
1997 328 I new fuel filter new trans filter with fluid. Auto trans no codes. Car idles good. Just slo slow take off.
Auto? Yikes ....
![]() Start by replacing the plugs, and inspecting the coil boots. Replace air filter if you haven't. This could be a VANOs issue, are hearing any rattling in the engine bay?
No noise from the vanos. The engine does not miss at all when I disconnect the maf the engine revs up great.
Have you tried cleaning the MAF?
If that makes a difference when unplugged.
Yes I cleaned the maf did not make a difference. Bought a new one off eBay but when I plugged it up the transmission warning light can on and the car shifts hard when driving.
Run Diagnostics for codes
search for TCM Transmission Control Module EDIT: Stomp Test does indeed apply ONLY to obd1
What good will the stomp test do the OP with a '97 328? I was of the understanding that was only for OBD I cars
Yes I know perfectly well, just not trying to start a fight.
multitasking.. dammit
he bought a maf from ebay. didnt someone from here do the same thing and their car ran like poo?
(unless he happened to get an oem one )
ere's something wrong with it. Quote:
Do you know anyone else with an E36 that you can swap MAF's with to test?
Ten four could it be the vanos unit. Does it advance the timing at a set rpm?
wait how many issues are you experiencing?
yes at around 3/3.5k rpms youll feel a sudden burst of power = vanos seals but then you mention the car doesnt misfire when you unplug the maf but before that you said it idles fine? im a little confused now
If it were the vanos.. it would be making a significant amount of noise.. Clean, Clean, Clean the MAF.. remove screens on MAF, use spray FIRST, (and LIGHTLY with q-tip if necessary) clean the element. Clean Throttle body Clean Throttle position sensor Check for vacuum leaks Check the hoses that are plumbed into the boot on intake Disconnect, clean, lube, and reconnect all associated electrical connections.
Why don't you put that in your sig? Then you could just put "Read below".
Quotes to live by: guessing gets expensive...drivinfaster nothing is more expensive than a cheap BMW...c4harpe13 Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff BMW-CCA #441426 1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia" I NEED A NAP, DANG IT! |
Unplug the VANOS solenoid and drive the car. If there is no difference, you need to replace the VANOS seals. http://www.beisansystems.com/procedu..._procedure.htm or http://www.drvanos.com/index.php?opt...&id=1&Itemid=2 |
![]() You made me laugh. +1 and 3 gold stars for you. :thumbs Quote:
![]() Interesting..
do you have a dvom?? if so, check the voltage @ the maf @ idle. iirc it should be at about 0.8v @ idle.
df
The electrical wire goes from the solenoid on the front edge of the motor (near the oil filter housing) to a connector underneath the intake manifold. It might be a little bit difficult to reach the connector, but you should see it. If there is no electrical signal to the solenoid, it will not apply oil pressure to the VANOS piston to advance the cam. However, if the VANOS piston seals are bad (which is very common on older cars), the oil pressure will also not advance the cam and you will experience poor performance. This is an easy way of diagnosing the VANOS with no cost in parts, nor any measurements. |
Now i know why my moms car stalls during cold weather warm ups Sent from my SPH-D710 using Bimmer App
