E34 (1989 - 1995)
Old 12-10-2012, 06:19 PM
jhkim jhkim is offline
Mein Auto: 525i
Damaged suspension cover ?
Recently I just checked the bottom of my car and found this. It looks like suspension rod is supposed to be covered with something like sponge. However it seems to be damaged by age. The rod still looks shiny so that is good news. How bad is this if I don't replace the cover ? It seems hard to replace it.
Old 12-11-2012, 01:06 AM
Mein Auto: 1989 525i M20B25
Looks like an old bump stop. It probably won't rust, but you may be more prone to bottoming out.
Old 12-16-2012, 09:44 PM
Tyannt Tyannt is offline
Send a message via Yahoo to Tyannt
Mein Auto: 95 540/6 Alusil
jhkim:
See item# 9 in the following link
http://www.realoem.com/bmw/showparts...28&hg=31&fg=10
Old 12-16-2012, 10:28 PM
Radian's Avatar
Radian Radian is offline
Mein Auto: '91 535i 5-spd
This means nothing more than that the piston rod chrome hasn't flaked or pitted. It does not mean the damper it's connected to is still good.
Originally Posted by jhkim View Post
How bad is this if I don't replace the cover?
Your ride quality won't be what it's supposed to be without it.
To replace the bump stop requires dissembling the strut a bit. By the looks of the wear shown in the pic, the front end could probably use some TLC all together. The stops normally don't get pulverized like that unless the dampers have been completely neglected for some time.
Good food, good people, good times.
Old 12-16-2012, 10:54 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
this
E30 above Sold
E34 V12 Project Thread Here: http://www.bimmerfest.com/forums/sho...=502437&page=4
Last updated 2nd January 2014
Old 12-20-2012, 05:30 PM
Mein Auto: 525i
Thanks for the link ! The name of it is "additional shock absorber". Then it means that it absorb less shocks then before. It seems like it is hard to replace them Good to know the name of it at least. Lots of remaining works for the car. Today it failed smog test.
Old 12-20-2012, 09:28 PM
yes to replace it requires removal and disassembly of the front strut. you may like to get a specialist to inspect the shocks and replace these at the same time, as there will be no further labour cost to do this.
its your car, but i would focus on getting it to pass smog first.
E30 above Sold
