Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series > F06 Gran Coupe (2013 - Current)
BMW's entrance into the 4 door coupe segment to go head to head with the Audi A7 and MB CLS
Old 12-10-2012, 05:22 PM
wassy's Avatar
wassy wassy is offline
BMW Enthusiast!
Mein Auto: '08 750i
M Performance Exhaust Installed on '13 640i GC
I didn't want to hijack another thread, so started a new one!
I had the M Performance Exhaust installed on my 2013 640i Gran Coupe. I'll give a brief synopsis of the install and results, and of course will answer questions as Best I can. I was not able to get great before or after clips, but nonetheless have a couple for you to hear, and plenty of pictures of the belly of the car and exhaust. There may be what looks like repetative pictures, but I tried to get different lighting to highlight what was important. Forgive me if there are too many.
The install was done by one of the BMW Centers best mechanics. He had also installed same on an F30 and 535i. Total time actually took about 2 hours, 45 minutes as we spent a bit of time fine tuning the position of the exhaust (more below).
He referred to the instructions on his system (none included in box) just to be sure, although was somewhat self explanatory. He found the referenced cutting marks on original exhaust pipe, and cut his way through the left muffler first. Not as quick as we would have liked, as the top wasn't easy to get the cutter's pressure on, vs. the rest of the pipe. Once cut, he unbolted the existing muffler hangers, supported the muffler, and removed it. The existing tips are welded on. My kit came with screw on tips (which I prefer anyway). We took a little time figuring out which way the clamp should be mounted, bolt wise, and mounted the hangers to the new muffler and hung it. The 2 metal pipes do NOT align exactly as they should, and in fact, aren't even really close for centering the tail pipe in it's place. Upon tightening the Clamp, the muffler moves out of center, and a bit of creativity and patience was needed.
Same was done for the right side, and of course quite a bit quicker. Once we got the mufflers to a point were both tips were equally spaced within its cutout, everything was rechecked as to torque, and placement. Tips were put on tight enough to drop car and check placement. A little here, a little there, and we got them where I like them best. Not too far out, but the M is noticeable if youre looking for it. If your not, you won't notice them anyway, for the average non-BMW enthusiast.
In the end, install wise, the tips are not perfectly centered within the holes. the have a slight tilt toward center of rear bumper and are edged closer to the inside of the cutouts than the outside. The tech and I could have spent more time attempting to bend the hanger rods to the exhausts or use some straps to shift the back just a tad, but we also know that the more we put tension on it, the more issues I'll have day to day, such as rattles, noises, etc. I'm happy with the placement and it no doubt fits as designed.
So, with the tail pipes firmly tightened, it was time for a sound check. WOW! I hadn't the foggiest idea what to expect, other than to trust my friends in Munich (or California Design) that they wouldn't disappoint, and they did not. It has an awesome, deep sound that is not obnoxious, is well liked and sounds awesome. In fact, a prior model M6 coupe was across the bay, getting revved up by it's mechanic. My little 640i sounded leaps and bounds better, and that's from all mechanics in the shop!
On the drive out, with building and car lot echoes, it sounded sweet. Hit the highway, and you absolutely know your exhaust was upgraded. Sounds amazing. At 70MPH, all windows up, with the drop of a gear or two, you hear it well inside the car. No drone! But you do hear it. Again, you know it's there. At normal drives, letting the car run in full auto, you get a nice, sweet sound for a few milliseconds, then again on gear changes, a few snap crackles and pops, and othewise, it's just great. Not intrusive, but much appreciated!
Enjoy the pics and video clips.
ID:	352661   Click image for larger version
ID:	352662   Click image for larger version
ID:	352663   Click image for larger version
ID:	352664   Click image for larger version
ID:	352666   Click image for larger version
ID:	352669   Click image for larger version
ID:	352670   Click image for larger version
ID:	352671   Click image for larger version
ID:	352673   Click image for larger version
ID:	352674   Click image for larger version
ID:	352675   Click image for larger version
ID:	352676   Click image for larger version
ID:	352678   Click image for larger version
ID:	352679   Click image for larger version
ID:	352680   Click image for larger version
ID:	352681   Click image for larger version
ID:	352683   Click image for larger version
ID:	352684   Click image for larger version
ID:	352685   Click image for larger version
ID:	352686   Click image for larger version
ID:	352688   Click image for larger version
ID:	352689   Click image for larger version
ID:	352690   Click image for larger version
ID:	352692   Click image for larger version
ID:	352698   Click image for larger version
ID:	352699   Click image for larger version
ID:	352700   Click image for larger version
ID:	352701   Click image for larger version
ID:	352705   Click image for larger version
ID:	352706   Click image for larger version
ID:	352707   Click image for larger version
ID:	352708   Click image for larger version
'13 640i Gran Coupe Alpine White/Cinnamon Brown, M-Sport, Driver Assistance, Lux Seating, Premium Sound, Full LED's
'10 Porsche Panamera S
'09 Maserati Quattroporte S
'08 550i Carbon Black/Natural Brown/Anthracite, Sport Pkg, Active Steering, Comfort access, Sport transmission, rear shades, NAV, Sirius, L7, Ipod/USB, PDC, Heated Front Seats.
'08 750i Sapphire Black/Natural Brown
'06 750i Sapphire Black/Natural Brown
'07 550i Sapphire Black/Black
'05 545i Silver Grey/Black
Old 12-10-2012, 05:40 PM
wassy's Avatar
BMW Enthusiast!
Mein Auto: '08 750i
and a couple more shots and the audio clips.
ID:	352713   Click image for larger version
Old 12-14-2012, 05:34 PM
ModBargains.com's Avatar
ModBargains.com ModBargains.com is offline
Mein Auto: E92
Car sounds amazing with the M performance exhaust!
We Specialize In: BMW Parts | BMW Tuning | VMR Wheels | Cobb AccessPORT N54 | Avant Garde Wheels | BMW Headlights
Alan Wei
| Alan@ModBargains.com | (714) 582-3330 ext. 8006
Hours: Monday - Friday 8:00am-7:00pm / Saturday 8:00am - 5:00pm (PST)
Old 12-14-2012, 09:52 PM
BigDeep1's Avatar
BigDeep1 BigDeep1 is offline
Festaholic
Mein Auto: 2011 535i Sport
Good sound. Your BOV is so audible! Me likey . Anything else done besides exhaust, that could contribute to the BOV being louder?
2011 535i Sport (Prem 1, 2)
Old 12-15-2012, 12:39 AM
smashhell smashhell is offline
Mein Auto: 2011 BMW 535i
Sounds great.
Don't know why they don't make these stock.
2011 535i Alpine White, Oyster on black interior, Premium 1 & 2 Package, Magnaflow Full Cat-back Exhaust, JB4 Stage 2
Old 12-15-2012, 05:51 AM
wassy's Avatar
BMW Enthusiast!
Mein Auto: '08 750i
No other add ons. I will say after a week with the exhaust, while it sounds great, it does carry somewhat inside the cabin. Maybe a little too much. It is less noticeable in SPORT mode. Dealer is going to check it out again Monday.
Best way to describe is that it kind of lingers with a bass that is quite noticeable until about 7th gear, all speeds. Again though, it a great sound, not disturbing but it does make me wonder a little. It not a reverb or bad drone, but if I had to use the word drone, I'd say its minor at best.
I love the little crackles that it makes at almost all gear changes at times. It isn't very often, but just right!
Old 12-15-2012, 06:44 AM
WB&BLUE5 WB&BLUE5 is offline
Mein Auto: BMW 535i
I put the M exhaust on my 535i 2011 and you described it perfectly. I had Magnaflow on before. Way way more drone.
Old 12-15-2012, 07:28 AM
wassy's Avatar
BMW Enthusiast!
Mein Auto: '08 750i
Which has more drone? The magma flow or m?
Old 12-15-2012, 05:33 PM
GirlLuvMyBMW640's Avatar
GirlLuvMyBMW640 GirlLuvMyBMW640 is offline
BeachBitch
Mein Auto: 2013 640i Gran Coupe
Huh. Never new how it was done. I just dropped the car off and picked it up at the EOD. Mine seem pretty centered. Didn't do any exact measuring but they looked fine to me. Congratulations!!
Name:	2012-12-15 17.22.37.jpg
ID:	353360   Click image for larger version
Name:	2012-12-15 17.22.56.jpg
Forget your Past but don't let it stop you. Tough times don't last. Tough people do.
My Car:
1994 E36 Convertible (Inherited from my Loving Father)
Carbon Black Metallic
Ivory White Nappa
Everything but B&O, Night Vision and Active Cruise Control.
