Old 12-10-2012, 08:14 PM
PittX52011 PittX52011 is offline
Mein Auto: 2011 X5, 2013 550 xi
Replacing kidney grills
Guys I tried to replace kidney grills by following the link below.
http://f10.5post.com/forums/showthread.php?t=42n2572
I was able to take off all the screws and clips but when I tried to pull the bumper forward I feared that I will cause bend in it (M sport bumper). I didn't force it too much and put the screws back.
The dealer is asking $150 in labor which seems excessive to me as most people mention that it takes 15-20 mins total.
Is there any other link or video I can follow. Thanks
Old 12-10-2012, 08:28 PM
Needsdecaf's Avatar
Needsdecaf Needsdecaf is offline
Everything's Bigger in TX
Mein Auto: 2007 MDX
http://f10.5post.com/forums/showthread.php?t=422572
Think this is the thread you tried to link?
If so, this works fine. You don't need to pull forward much. Just get it started with the top clip and the rest will start popping out. You can do the bottom clips from inside once you get the top loosened. You'll know what I mean once you start it.
2011 535i
Sophisto Grau / Oyster - Black Nappa, Anthracite Wood Gone but not forgotten.
Heaven is where the police are British, the cooks are French, the cars are German, the lovers are Italian and it is all organised by the Swiss.
Hell is where the police are German, the cooks are English, the cars are French, the lovers are Swiss, and it is all organised by the Italians
Old 12-10-2012, 09:17 PM
OrthoPT OrthoPT is offline
Mein Auto: 2011 535i xdrive
Just pay the dealer. Its only 150.00 and it gets done right. Plus no stress. How much time did you spend on it already?
Sent from my SCH-I535 using Bimmer App
Old 12-10-2012, 09:29 PM
Houseofpang Houseofpang is offline
Mein Auto: 528i M
I just put on some gloves, grabbed the middle fins and pulled out the top tabs then the bottoms.
Old 12-10-2012, 09:32 PM
Cdgiles Cdgiles is offline
Mein Auto: 2012 550i
I was able to replace them myself a couple of weeks ago in about 20 mins. You can tug harder than you think.
Old 12-10-2012, 09:46 PM
passer68 passer68 is offline
Mein Auto: 2012 550i xDrive M sport
uhh, i did it in like 30 seconds a side. just pulled with a deliberate and constant pressure. omg, 150 dollars.
2015 Yukon XL Denali
2012 550i xDrive M sport Dark Graphite Metallic /Cinnamon
2009 Nissan GT-R
1997 Porsche 911 Cabriolet
1970 Chevelle SS 396
Old 12-10-2012, 10:14 PM
Mein Auto: 528i M
Yea that's the word I was looking for too, it's ok to pull with force, just make sure it is slow and constant pressure, don't yank fast.
Old 12-11-2012, 08:11 AM
RambleJ RambleJ is offline
Mein Auto: 2012 535i M-sport
I will beat the dealer and do it for $100
Its really easy. It takes a lot more tuggung than you think. And if you think the dealership is going to be any gentler than you would, you might want to think twice.
There is no special grill removal tool that the dealers use, just put some back into it and pull them bad boys out!
2012 535i M-Sport
Previous BMW's: 87' 528e / 04' 325i / 07' 335i / 08' 335i / 08' 535i
Old 12-11-2012, 08:26 AM
BigDeep1's Avatar
BigDeep1 BigDeep1 is offline
Festaholic
Mein Auto: 2011 535i Sport
The best advice I read, and could give is that don't worry about putting a "crease" or damaging that front bumper. It is very resilient and can peel back without damage. I actually had to bend and pull it out far enough to reach my hand in and release the top AND bottom clips. I really struggled with it and totally did not agree that it was a 20 minute job. I will say that once I gained the confidence to bend the bumper far enough to reach my hand in, the other side only took a few minutes.
2011 535i Sport (Prem 1, 2)
Old 12-11-2012, 10:57 AM
MWPos MWPos is offline
Mein Auto: 2013 535i
Gloves, or a thin towel stuffed in between the fins when you reach in to pull are a great way to protect your knuckles from losing a lot of skin. It really only takes a minute per side, and a few pounds of pressure. No tools, no unscrewing the bumper.
ID:	352838   Click image for larger version
Old 12-11-2012, 11:10 AM
bighungry618's Avatar
bighungry618 bighungry618 is offline
Serious About Shine
Send a message via Yahoo to bighungry618
Mein Auto: 2011 535i M-Sport
Steps follow below:
1. Grab vertical slats (fins) near the top with your hands evenly spaced apart on the grille....
2. Wiggle and pull slightly down (towards the ground) and towards you firmly but gently.
3. Drink adult beverage.
4. Repeat step 3
Boom...F10 grille removal complete.
"IRENE" = 2011 535i M-Sport, Jet Black/Black Dakota, Premium, Cold
Mods:
JB4 Stage 2, Black Grille Surrounds, Black Fender Signal Trim, Body color front / rear reflectors and rear diffuser, DeBadged, 20% LLumar ATR premium tint.
To keep your car looking its very best:
Detailed Image Auto Detailing Supplies
Old 12-11-2012, 07:46 PM
Thanks all of you. I agree, that's what I was scared of, that I may put a crease or dent in the front bumper as it is attached at the bottom and open at the top.
What I understand is that I should pull each side individually by holding each grill from the middle rather than pulling the center of the bumper. Right?
Now I will give it a more manly pull. Project for the weekend.
Thanks for the input again.
Old 12-11-2012, 08:14 PM
The grills should be pulled out one at a time, per BigHungry618's step-by-step above. Both hands are needed on the grill which is being removed and the hands' position will be nearer the left and right edges than near the center. The bumper should not move.
Old 12-11-2012, 08:35 PM
JT 550i SD's Avatar
JT 550i SD JT 550i SD is offline
Mein Auto: 2011 550i M Sport
I did the exact same thing- took 5 minutes including cleaning grille area - new grilles snap right in- no tools, just careful soft but firm pull/tug.
2011 550i : Alpine White l Black Dakota l Anthracite wood:M Sport pkg l Sport Trans l Active steering l Conven pkg l Driver asst pkg l Prem pkg 2 l 4 zone AC l Side/Top view cameras l HUD w/6wa ext blk pnl l BMW Media adptr /apps l M Decklid Spoiler l Clear Bra l V1 Radar; Ordered 4/9/11, Delivered 5/21/11
Retired BMW's;
-2008 550i MSport: deep Sea Blue/ Black, Loaded
-2005 545i : Silver Gray/ Auburn, Loaded
-1993 3215iA : Jet Black/ Black, Loaded[/FONT]
Old 12-12-2012, 07:37 AM
Thanks guys. Just to make sure that I understand it right, I open the screws from the top of front bumper. After they are out, holding the grill I tug out and down, putting the other hand in the space behind the bumper and grill to undo the clips.
OR
I don't need to unscrew the the top of bumper. I just hold each grill with two hand and pull down and out firmly but gently.
1 or 2.
Old 12-12-2012, 07:39 AM
Needsdecaf's Avatar
Mein Auto: 2007 MDX
OR
1 or 2.
Correct, your choice. I went with one as i didn't want to risk breaking clips.
2011 535i
Old 12-12-2012, 04:42 PM
I just came home from a drive-by on my Encinitas San Diego BMW dealership. I asked for their expert opinion on how to do the grill removal. The parts and body shop guys met me at my car and they showed me how they do it. They just yank those bad-boys right out. The body shop guy took mine out and put them back in less than a minute just to make his point that it is very easy to do. (he also made a point of telling me what a LOUSY job I did in painting my grill's rings That will teach me to be careful about asking for an expert's advice!)
I did notice that his technique was to pull outwards and downwards with his hands holding the fins a few spaces in from the edges.
Old 12-12-2012, 05:28 PM
CyclePath1's Avatar
CyclePath1 CyclePath1 is offline
Ride On!
Mein Auto: 2012 535i MSport
I chose option #2.
My advice if you opt to go this route is to look at the new grills and make note of where the tabs would be on the old grill. Then use firm and steady force on each tab area. Taking the top off first then moving to the bottom tabs. Use gloves or a towel to prevent scraping your hands because you will need to put some muscle into it.
BMWCCA #474327
2012 F10 535i MSport
mods: Vollkommen front lip|M5 grill|M5 exhaust|M5 diffuser|Vibrant resonator|BMS stage 1|ACS springs|Suntek full front-end clearbra|FormulaOne Pinnacle tint 35%|clear reflectors|rear fog light switch|JBL ms-8 audio processor|Morel subwoofer
Old 12-13-2012, 09:33 AM
Keyser Soze's Avatar
Keyser Soze Keyser Soze is offline
just like that, he's gone
Mein Auto: 2013 535
I pulled mine out in about 20 seconds each side. Just pull carefully and firmly. It will massively help if it's really hot out and the car is warm as well, they will slide right out. I did it after a 400 mile journey in 90-100 degree heat back in September.
You also don't want to wait a few years to do it, then you will shatter all the tabs (based on E46's I've owned)
2013 F10 535i M-Sport, Sophisto Grau, 6-speed MT
2011 E90 335i Sport, Jet Black, Sport Auto, Performance Edition
2002 E46 330i Sport, Jet Black, 5-speed MT, lots of upgrades
2001 E46 330Ci Sport, Steel Grey, 5-speed MT....and more
Old 12-15-2012, 10:44 PM
Thanks for the help. It just took me less than 5 minutes to replace both grills. Black grills really like nice on CBM.
Old 12-18-2012, 03:16 PM
mlaynemd's Avatar
mlaynemd mlaynemd is offline
Mein Auto: F10 M5
Nothing a set of OEM Performance Gloss Black kidneys won't fix!
F10 M5 Alpine/Sakhir
Old 12-18-2012, 05:34 PM
True! Can't wait to get them One picture is the car with flat black grilles and surrounds, which I did not like. the other picture is my DIY attempt at painting the surrounds to be space gray. Within a few days, the chrome was popping through where rocks and small debris had hit the car
With gloss black grilles and surrounds, I am hopeful that a well-done paint job will stick better on the gloss black surrounds than it did on chrome!
ID:	353748   Click image for larger version
Old 01-26-2013, 11:07 AM
skymast skymast is offline
Mein Auto: 2012 BMW 535
I just did this, the yank is the way to go. Like someone said, this is a 30 sec / side DIY.
2012 BMW 535 ... Silver / Black, M Sport, Premium, Premium Sound, Technology, Heated Seats, Sport Automatic
Other Cars ... Mercedes S550, Chevrolet Tahoe LTZ, Porsche 996 Turbo
Old 01-26-2013, 11:24 AM
JPetrillo JPetrillo is offline
Mein Auto: 2013 528xi
When I did mine, I was gentle and took about 15 - 20min to get the first grille out. Then when I did the second grille, I unclipped the top tabs (2 minutes) and gave the grille one good/strong yank and it immediately popped out seemlessly!
2013 528i xDrive Black Sapphire Metallic
Mods:
35% Madico Onyx Tints
Painted Front Reflectors
Debadged
Custom M Performance Grilles
M Performance V-Spoke 20" Wheels
18mm BMS Rear Spacers
M5 Style Spoiler
M Sport Rear Bumper with Painted Reflectors & M5 Diffuser
GTHAUS Meisterschaft Full Cat-back True Dual Exhaust 4x90mm GTC EV Controlled
Evolution Racewerks Catless Downpipe
BMS Stage 1 Tune (pending)
(Picture not up to date with current mods)
Old 01-26-2013, 03:45 PM
kckc1016 kckc1016 is offline
Mein Auto: 2012 550 xDrive
im shocked that there isnt more theft of these grills if the yank is that easy.
2012 550 xDrive
