BMW Coding and Programming
Discuss coding options and features on your BMW here. |
Retrofit 609
I have the 609 hardware FSC enabled for my car. I modified the VO, added 609 and wrote it to the car. Now which ECUs I need to code ? Or what is the approach in enabling 609 ? The original SVT with the ECUs in my car attached. I know HU_CHAMP will change to HU_CIC once the hardware is installed. Car was at I-Step 507 and now after some other coded values, it is at 512.
Regards, Alex 2012 w204 Mercedes-Benz C350 4MATIC MY 05/2012 Black/Sahara 2011 F10 535i xDrive MY 01/2011 Sophisto Grey/Black Last edited by gicamuci; 12-11-2012 at 09:48 AM. |
I would VO Code HU_CIC, KOMBI, and CMB_MEDIA, and CMB_ECALL. The FSC Code in the Head Unit, is this a new one for your F10 VIN, or did it come with the donor CIC?
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ |
Hi Shawn,
thank you so much for answering my questions. I hope you will have the time to read my explanation bellow to better understand the problem I am facing. Quote:
Here is the whole story: I bought this retrofit kit from bimmerretrofit and got it installed and coded by them. It was working fine until I had to visit my dealer for a seat error code. Dealer said my car would need the global update, so I said okay, do the global update too. Only they called me after 5 hours of trying (so they told me) saying they can't proceed with the global update, because the original Head Unit and the display were changed. They also told me that if I want them to retry it, then I would have to reinstall the original Head Unit and display. I agreed and I am due next month for this. Now the problem. Since the car was at the dealer, the Navi doesn't work anymore, placing the car way off on the map. Going into the service menu, GPS section, it is saying "No GPS available" and the almanach has always a value of 0 satellites. I think while clearing the error code for the seat, they must have changed something that disabled the Navi. I have a backup of the original CAFs, not all of them though (only for CAS, JBBFE, KOMBI, IHKA, DSC_Premium, HU_CHAMP and FRM). I also have a backup of all the CAFs, FA and SVT that I took a few days after the 609 retrofit. I guess I will have to try and recode the modules you mentioned, using the CAFs from my backup after the retrofit, right ? Appreciate your help.
Regards, Alex 2012 w204 Mercedes-Benz C350 4MATIC MY 05/2012 Black/Sahara 2011 F10 535i xDrive MY 01/2011 Sophisto Grey/Black |
In E-Sys, "Expert" = > "Coding" module, under "Vehicle Order" after you select "Read" and read your VO, click the "Save" button and then the "Edit" button, and your VO (FA) will open in the FA-Editor. Under "FAList", expand "FA", expand "FZAuftrag", expand "Type" and click on "SALAPA-Element". All your option codes will appear in the lower window, where you can edit and save them. Once you modify the VO, your need to save it again.
Then when you want to VO Code a module, you need to go to "Expert" = > "Coding" module, Load that saved modified FA, Activate the FA, and then for each ECU that you want to VO Code, right-click on the ECU (the ECU itself and not the underlying CAFD) and select CODE. Unlike FDL Coding, which makes individual parameter changes to an ECU, VO Coding will apply the VO to the module and code the entire module (all paramaters) to support the VO. As for your Navi problem, my fear is ISTA/P terminated your new FSC Code. In E-Sys, "Comfort" = > "FSC" module, select the "Check FSC Status", and copy and paste your results from the log window back here.
Here is the FSC status result:
--> Read the state from "1" ECU(s) <-- HU_CIC[DiagAddress=99] 0000000000C873912 RootCertStatus accepted SigSCertStatus accepted SWSigStatus accepted SWTApplications ---------- AppID 23 UpgradeIndex 1 SWTType SWTclassic full FSCStatus rejected FSCCertStatus accepted ---------- AppID 25 UpgradeIndex 1 SWTType SWTclassic full FSCStatus accepted FSCCertStatus accepted ---------- AppID 27 UpgradeIndex 1 SWTType SWTclassic full FSCStatus accepted FSCCertStatus accepted ---------- AppID 111 UpgradeIndex 1 SWTType SWTclassic full FSCStatus accepted FSCCertStatus accepted ---------- AppID 156 UpgradeIndex 1 SWTType SWTclassic full FSCStatus not available FSCCertStatus accepted ---------- AppID 155 UpgradeIndex 1 SWTType SWTclassic full FSCStatus not available FSCCertStatus accepted ---------- AppID 45 UpgradeIndex 4 SWTType SWTshort FSCStatus accepted FSCCertStatus not available
AppID 27 is your Map for Navigation, and it looks good. AppID 23 is your Voice Recognition, and that one is Rejected.
Damn Shawn, how do you know all that
![]() Respect!! |
This morning, before going to the office, I had the time only to read the FSC status and also to VO code the HU_CIC. I just learned that after a VO code, a FDL code is needed (which I did not do) cause the HU_CIC is back to its state without any options I did modified previously. For example now I am back to the old style audio player and no DVD in motion. I can say that after VO coding only the HU_CIC, looking into the service menu, still says "No GPS available". So tonight or tomorrow morning I will VO code the KOMBI, CMB_MEDIA and CMB_ECALL and will try to see how it works before FDL coding them. I'll let you know how it goes.
Searching through the FDLs for GPS, this is what I found:
In CMB_MEDIA there are only two settings that reference the GPS, both in 3006 TELEMATIK. One is the GPS_FROM_MOST (nicht_aktiv in my settings) and the other is the GPS_POSITION_TIMEOUT (5_Minuten in my settings). In the CMB_ECALL there is only one reference to GPS, in 3001 TELEMATICS -> ECALL_GPS_ENABLED (nicht_activ in my settings) In HU_CIC -> 3000 theres one reference to GPS, SYSTEM_GPS_RECEIVER (aktiv in my settings). Then there are two others in 3003 TELEFON_TELEMATIK_ONLINE. One is GPS_FROM_NAVI (aktiv in my settings) and NAVI_INFO_INSTANCE_ID ( wert_1 in my settings) with possible values as 1=NAVI, 2=TCU and 3=Combox. In KOMBI there is again only one interesting setting in 3000 Anzeige_Konfiguration -> GPS_UHR (aktiv in my settings) which should enable/disable the clock sync from GPS. To verify this, once my Nav will get fixed (or someone with a functional Nav can try it), I will set the clock 1 hour behind and it will be interesting to see if the clock will get set.
Regards, Alex 2012 w204 Mercedes-Benz C350 4MATIC MY 05/2012 Black/Sahara 2011 F10 535i xDrive MY 01/2011 Sophisto Grey/Black Last edited by gicamuci; 12-13-2012 at 08:10 AM. |
So, lets see what you have after VO Coding KOMBI, CMB_MEDIA, and CMB_ECALL. Make sure you have 609 in the FA you activate for the VO Coding.
Made sure I had 609 in the FA and activated. VO Coded the three modules left KOMBI, CMB_MEDIA, and CMB_ECALL. Drove around the block. No joy. Still shows "No GPS available" in the service menu and the position on the map is off by a few tens of miles.
While at it I FDL coded the HU_CIC with the power/torque meters and the xdrive distribution menu. None of them works. In fact the distribution menu just shows but it is greyed out even though the car is xdrive.
Are you positive the GPS antenna connection is made properly at the back of the CIC?
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ Last edited by shawnsheridan; 12-13-2012 at 05:31 PM. |
None. I don't know which SA to remove.
I attached the FAs and SVTs before and after the hardware install. I remember I almost broke my nails trying to remove those connectors at the back of the Head Unit when I did swapped them. But then strange things could happen. It is something I would need to check, but the possibilities are slim.
What is your short VIN?
Navigation was working fine two weeks ago.
I sent a pm with the VIN. Sent from my SGH-I717D using Bimmer App
Well, short of the GPS antenna connector being an issue, I don't have any ideas. For good measure though, I would also VO Code CAS, ICM, and JBBF. If that doesn't work, I'd ask Alex at BimmerRetrofit what the issue could be. They have probably seen it all there, and as a customer, I'm sure they would be helpful.
Thank you Shawn for your time and patience. Season's greetings !!!
Ok. Good luck, and let us know the outcome.
Was reading on some other forum and just saw that people retrofitting CICs in their cars, besides 609, they are also adding 6VA.
E-Sys already replaced HU_CHAMP with HU_CIC, so I don't think that is necessary.
If anyone can please help me with reading these 10 values that you are having on your car (with NAV) in modules: KOMBI, HU_CIC, COMBOX_EMEDIA AND COMBOX_ECALL.
I did attach an excel file in which it will be easy to input the values. Just remove the .pdf in its name. Appreciate your help. Thanks.
![]() Mine though are all the same as yours.
I'm at the end of ideas... But still don't want to accept that something is wrong with the actual CIC or antenna.
Last night I used the original FA and VO Coded KOMBI, CMB_MEDIA, CMB_ECALL, CAS, FRM with F010-11-09-507 and FDL coded the original CAFs. Then switched to F010-12-03-512 and FDL coded (not VO coded) the HU_CIC with its backup I took after I installed it. In my mind, like this, it should be back to its "original" state after I installed the HU. But maybe I am wrong... good thing I don't have a hammer near me ![]() This morning I used the Assist service in the car (no BT connection to my phone) and asked the girl that took the call, if she can tell me where I am at that moment. I was in Canada alright, just not in Montreal from the position she gave me.
#25
Did an offline comparison and found that in SVT, besides the swap between HU_CHAMP and HU_CIC another module gets disabled but not removed. The module is CID.
Does the CID module exists on cars with HU_CICs ? Somehow I don't have in any of my backups the .ncd file for this module (CAFD_00000186_007_005_000.ncd).
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
