The X5 SAV Forum
Old 12-11-2012, 07:34 AM
hussaintm hussaintm is offline
Mein Auto: x5
key lock system
Hi,
I am facing a problem with key lock system “ for X5 2003 “. As my new key can’t be programmed to open door and back door using key buttons in the key.
I had to replace some parts of key control system “ part located under steering wheel, and part located in the a box top left of the engine “. My car is European standard, and two new used parts are
US standard, as they have been removed from a used car.
Even it is not possible to program old key just to be used to open doo remotely and open back door.
Really I appreciate any help regarding above.
Regards,
Old 12-11-2012, 08:10 AM
QSilver7's Avatar
QSilver7 QSilver7 is online now
What RF (radio frequency) is your new key or parts? You mention something about parts coming from a US vehicle...if so...the US BMWs communicate over the 315 MHz RF signal...whereas European BMWs use the 413 MHz RF signal.
Q {BMW CCA Member #191509}
(SOLD)
Old 12-11-2012, 09:38 AM
Mein Auto: x5
Thanks for your reply.
I am not sure about RF, but i think it is 315 MHz, as new parts are taken from US BMW car.
Which parts in the car affects operations for buttons on the car key? as I did not change all parts related to key lock system.
Old 12-11-2012, 11:40 AM
QSilver7's Avatar
FZV & DWA (central locking/anti-theft alarm siren systems) Info
The remote keys contain 3 different technologies (EWS/FZV/DWA) which work in conjunction with each other. The problems you describe sounds like you're having issues with FZV & DWA.
Here's a link to a BMW Technical document (PDF) that goes into detail about FZV (central locking system) as well as DWA (anti-theft alarm siren system) in way more details than I can write...maybe it can help explain some of the issues you are having: http://www.bmwmotorsports.org/BMW_do...lectronics.pdf
(SOLD)
