Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > Z Series > E89 Z4 (2009 - current)
Old 12-11-2012, 08:36 AM
jjswart jjswart is offline
Mein Auto: 2003 z-4
Z-4 windshield washer pump
How do you replace a windshield washer pump?
Old 12-11-2012, 05:55 PM
RufusKing RufusKing is offline
Send a message via MSN to RufusKing
Mein Auto: Z4 3.0i Roadster
it should be fairly simple. Just remove the resevoir and pump then detact the wires. The pump should be mounted to the tank. disassemble and replace then reinstall in reverse order.
This one is called OPey
2009 BMW Z4 sDrive 3.0i
I call her weezey
2006 BMW Z4 3.0i Roadster - Sold and I miss her.
Old 12-18-2012, 02:15 PM
ChuckE89's Avatar
ChuckE89 ChuckE89 is offline
Mein Auto: E81, E89
the pump for the windshield is the one on the rear, towards the firewall. push it towards the rear of the car a bit [like 1/2"] and then pull up and wiggle, and by wiggle, I mean you will dwarf your efforts to get away with forgetting your anniversary, it should move pretty much straight up, and hopefully the strainer will come with it. If you are replacing the pump, then best to replace he strainer also. If the strainer does not come out with the pump, then you will need to grab it with some needle-nose pliers. and get it out, as the strainer usually clogs pretty easy and you may find the pump is good, but the strainer is not.
_________________________
2007 120d Limited Sport Ed
2009 sDrive30
HTML code is Off
