E36 (1991 - 1999)
Old 12-11-2012, 09:49 AM
VicVegas84 VicVegas84 is offline
Mein Auto: 98 Cosmos 3/4/5 87k
Advice & Opinions Needed: Blown HG - 98 M3/4/5 88k miles
Hi Guys,
I recently discovered I've had a HG failure. Very disappointing as my car only has 88k, hasn't been tracked and has been well maintained. I'm concerned the head might be cracked as well. Whats interesting is I believe the car never overheated. Spirited drives have lasted no longer than 10 minutes on back roads, and I've kept a close eye on temp on the highway.
Right now, the car is going in storage for the winter anyway as its a secondary car. The car also needs a throw out bearing, so I will need to replace the clutch as well when I fix the car. I will be doing the work myself. I'm looking for opinions on where to go from here. I have a couple of things in mind.
Option 1: Take off/inspect head. IF not cracked, have it decked. Replace HG, Reinstall with ARP hardware.
Option 2: Take off/inspect head. If not cracked have it decked. Replace cams with something aftermarket. Reinstall with ARP hardware. Install LW flywheel with clutch replacement.
Option 3: Take off/inspect head. If not cracked have it decked. Reinstall with ARP and a head spacer. Complete with a supercharger build. (I'm not sure if headspacers are available or recommended)
Option 4: Head is cracked. Purchase a rebuilt head, reassemble with ARP hardware.
Option 5: Head is cracked. Purchase/Install Euro S52B32. Repair NA motor in spare time, sell when complete.
This is my first experience with a BMW. I've owned the car for 3k miles, and while its the most fun car I've ever owned, its also been the most trouble. I currently have another money pit project, a mk2 GTI VR6T.
What I'm looking for, is to hear from people who have been in my shoes, gone with a set of cams, owned a supercharged car or a Euro swapped car, and the costs associated.
Thoughts and opinions greatly appreciated.
Thank you in Advance.
Old 12-11-2012, 10:01 AM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
You're looking at serious money for a euro S52B32, so I'd probably throw that idea out right away. As far as whether or not to install cams and/or a supercharger, it depends on what you want to do with the car.
If it were my car, I'd just repair it to stock condition, but use ARP head studs.
1998 BMW 328is
1966 Pontiac GTO
Old 12-11-2012, 10:07 AM
My thought is I can recoup some of the costs by selling my motor/trans. I will definitely by using ARP hardware, as thats personally why I think the HG failed; probably on a downshift I didn't rev match well.
Current Stable: 1975 TVR 2500m | 1998 M3/4/5 | 1991 GTi VR6T | 1995 Saab 900SE V6 Vert | 2002 Nissan Xterra
Old 12-11-2012, 10:31 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Whole lot going on here!
1) There was no Euro S52, only the S50B30 and S50B32. Using this engine will cause a bunch of regulation headaches, and isn't worth the hassle anymore.
2) IMO, you're better off implanting an S54.
3) If you're going to salvage THIS engine, I'd recommend taking it out to work on it.
4) Cams and S/C will change this car from great, to beast. Just use a thicker Head Gasket to lower the compression a bit.
What is your budget for this job? At the very least it sounds like you'll need a new HG. If you can do it all on your own and you take all winter it will be pretty inexpensive. Buying a new engine and doing cams/SC is going to bump this up towards $10k.
Sounds like fun, though!
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by hornhospital View Post
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
Old 12-11-2012, 10:33 AM
petriej's Avatar
Update: This guy is breaking (parting out for us yanks) his 97 M3.
Maybe he'll set you up with his engine. Make sure you get it 'long block' style.
Ugh, now that it's on my mind I can't stop looking into it. Here's another in the UK.
GGC BMW CCA #443004
Join the BMW CCA!
Old 12-11-2012, 11:09 AM
Mr Gusta's Avatar
Mr Gusta Mr Gusta is offline
Fireballs inc.
Send a message via AIM to Mr Gusta
Mein Auto: big turbo hellrot sedan
no such thing as a euro s52b32, its an s50b32
if I were you, stock hg and arp hardware, along with a supercharger build and never worry about it again
Turbo lag is just a headstart because the chase is more exciting than the win - Abraham Lincoln
Old 12-11-2012, 12:34 PM
ZeGerman's Avatar
Warm Leatherette
I agree that the S54 makes more sense, but just for reference, there are no emissions regulations to comply with in the OP's state of Michigan.
1998 BMW 328is
1966 Pontiac GTO
