Old 12-11-2012, 09:36 AM
wjjklj's Avatar
wjjklj wjjklj is offline
Certified 7
Mein Auto: 2004 745i
Help with Fault Code
Anyone know what this means? No symptoms. Car runs great.
Old 12-11-2012, 11:49 AM
GeorgeT's Avatar
GeorgeT GeorgeT is offline
Mein Auto: '07 750i BMW; '03 Z4 BMW
Probably that someone will make a boatload of money fixing whtever is wrong.
Old 12-11-2012, 11:56 AM
wjjklj's Avatar
Certified 7
Error code is 8E111 in hidden menu.
Old 12-11-2012, 11:59 AM
First_745Li's Avatar
First_745Li First_745Li is offline
Mein Auto: 2003 745Li
I thought I saw that code a while back. No idea what it means.
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
Old 12-11-2012, 12:11 PM
hd750Li's Avatar
hd750Li hd750Li is offline
Mein Auto: 2008/2011 750Li
If I'm not mistaken....it's a THERMOSTATIC error.
Old 12-11-2012, 12:23 PM
johndade johndade is offline
Mein Auto: 2002 bmw 745li
I also have that similar code but the few different numbers at end. Dont know what they mean either.
Old 12-11-2012, 12:33 PM
wjjklj's Avatar
Certified 7
I replaced the thermostat and entire coolant system recently. Engine temp seems correct in hidden menu. What exactly is thermostatic error other than the engine thermostat? Thanks.
Old 12-11-2012, 12:44 PM
I just ordered the thermostat, hadn't had the chance to do anything.
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
Old 12-11-2012, 01:51 PM
hd750Li's Avatar
Have you tried to clear the errors after the thermostat got replaced?
Old 12-11-2012, 02:28 PM
wjjklj's Avatar
Certified 7
Yes
Old 12-12-2012, 06:29 AM
hd750Li's Avatar
When you checked the faults using INPA (presumably), which module did the fault appear in?
Old 12-13-2012, 04:03 PM
wjjklj's Avatar
Certified 7
Here is a screenshot of INPA
Old 12-13-2012, 06:40 PM
hd750Li's Avatar
Hmm....I just scanned my E66....got the same error in KOMBI. I'm not experiencing anything different or abnormal.
I will have my Autozone's guy scanned it and hopefully get that hex error translated into something more understandable.
Old 12-13-2012, 07:19 PM
wjjklj's Avatar
Certified 7
Sorry you have the error too....thanks for checking out. Definitely let me know if you shed any light on what this means. Thanks again.
Old 12-17-2012, 04:57 AM
hd750Li's Avatar
Well, my Autozone guy scanned the error...."cold temperature warning". He cleared the fault. It hasn't come back for several days. It's been warm here in Texas.
I checked my engine temp...never higher than 102.
He said, it might be related to other issue but for now I shouldn't be worried about it.
Old 01-31-2013, 12:18 PM
Sorry to revive an old thread, I'm getting a similar reading... not sure what it means will check INPA later tonight. Car drives fine, nothing out of the ordinary. I changed my thermostat about a month or so ago and cleared all codes so I know this is new.
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
Old 01-31-2013, 08:17 PM
So below are some screenshots of faults from INPA, I was getting some compile and other errors trying to use INPA. But below are what I was able to get, hopefully someone can give me some insight on what it all means. I once again cleared them,
ID:	360075   Click image for larger version
ID:	360076   Click image for larger version
ID:	360077   Click image for larger version
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
Old 02-01-2013, 01:29 AM
Piers1989 Piers1989 is offline
Mein Auto: E65 745i
I'm afraid I don't know off hand, but I would say its likley what the "D" ones all in close range of each other may be CAN errors, which arent much to worry about.
Can you not access the seperate modules for diagnosis with INPA?
Old 02-01-2013, 06:25 AM
When I try to access each module I get errors. I'll have to run INPA again and get the errors.. But to answer your question, No, I get the errors and goes back the the previous menu.
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
Old 02-01-2013, 06:34 AM
So I cleared the faults last night, same fault posted again...
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
Old 02-01-2013, 08:59 AM
wjjklj's Avatar
Certified 7
My fault came back also after clearing. Have you checked your bottom hose temperature of the cooling system with INPA? My hose always ran too cool according to SFBay (see recent coolant thread). He says this means my coolant pipe running through the valley pan his leaking. Theory is that it is leaking but not bad enough to come out the weep hole. This causes the engine temp to climb above 105 degrees celsius when at idle even though the thermostat is rated at 105 degrees. Mine will get to 107 degrees at idle. Maybe this is what is giving the cold temperature error 8E111 because the bottom hose is too cold. Just a theory....trading mine in today.
Old 02-01-2013, 09:05 AM
Man I hope that's not the case. I've been following that thread closely as well. I'm not familiar enough with INPA to check the temp of the bottom hose. Can you help me navigate thru INPA to get this information? I'll have to do it Sun or Monday because in a few hours I'm headed up to Orlando for the weekend (not using the 7). I was at 105 idling this morning, but went down to 101 when I started moving. Can't wait to see pics..
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
Old 02-01-2013, 09:28 AM
wjjklj's Avatar
Certified 7
Go into INPA. Select the engine function at the top, then pick N62. Select status and then analog 1. See screenshot below.
Old 02-01-2013, 09:30 AM
Thanks. I'll check it out and post what I find.
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
Old 02-01-2013, 10:00 AM
Nygel's Avatar
Nygel Nygel is online now
Mein Auto: BMW 750Li
thermostat is dragging, means the inlet and outlet temps are too far from each other. I seen this before. Time to change STAT.
