Old 12-11-2012, 12:43 PM
Roman-dude Roman-dude is offline
Mein Auto: 2011 335d
TPMS check if works?
the winter tires i picked up had older TPMS, so i got the new (used) ones to replace those and should have them installed shortly. but since that'll involve balancing the tires, i'd like to be able to check if TPMS's are actually in a good working order.. you know, to avoid rebalancing again.. is there a good way to quickly check that?
thx
Loving every mile of it!
Old 12-11-2012, 05:13 PM
pointandgo's Avatar
Mein Auto: '13 F10 535i (loaner)
thx
A tire shop (such as a Firestone company store) with a hi-tech TPMS diagnostic tool should be able to test and tell you if the TPMS are in working order and of the correct frequency for your car. Your dealership should also be able to do this...$$$.
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
MBz W124 300E (slammed)
(unmentionables in between)
Member: BMW CCA
Old 12-11-2012, 07:24 PM
DSXMachina's Avatar
Bimmerdex 7.4!
Snap-On makes an actual bench top chamber where a TPM can be live tested. I don't know of any device which can do a complete function test other than that. We have devices which can query a monitor, basically tell it to wake up and talk to me, but until it's installed under pressure you never know for sure if everything works.
I'd go ahead and install the monitors. If one is no good the car will tell you which one and you can just pop the bead on one side of that wheel and install another monitor without having to rebalance the wheel.
Old 12-12-2012, 04:43 AM
gpburdell gpburdell is offline
Mein Auto: 2010 335i Cabrio
nm, misunderstood the question
Old 12-12-2012, 05:08 AM
MP3_E46's Avatar
MP3_E46 MP3_E46 is offline
Code/wrench Monkey
Mein Auto: Carefully
Let ~4psi out of one tire and drive for a mile or two?
Six Euro Deliveries since December 1998 (Owned E46, E90, E91, E92 and E93)
28 vehicles in 26 years of driving so far. Guess I like cars
Old 12-12-2012, 05:18 AM
That's where I was going, but OP's looking to test the monitors BEFORE putting the tires on the rims and having them balanced.
Old 12-12-2012, 05:31 AM
thanks, all.. replacing and hoping they work it is then.
