Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > BMW i3 / i8 / ActiveE / MiniE
Are you excited about the upcoming BMW i3 or i8? Interested in learning more about the BMW ActiveE? This is the place for you!
Old 11-30-2012, 06:44 AM
Andrew*Debbie's Avatar
Andrew*Debbie Andrew*Debbie is offline
resU deretsigeR
Mein Auto: Z4 sDrive20i
Chameleon charger. Will BMW use it?
One glaring omission in the i3 skeleton is the charger. Motor, battery and inverter are all there to see, but no charger.
BMW hasn't said much about the charger in their press releases either.
I wondering if BMW is licensing the Chameleon charger from Renault. It is to both companies advantage if they both use the same fast charger connector. Also the existing charger infrastructure around Munich is compatible with Chameleon.
To date, AC charging has been "slow" with a full charge taking around 6 to 8 hours. Fast chargers are DC. DC fast chargers are big expensive boxes.
Renault's patent improves on an existing brilliant idea: Reuse parts in the drivetrain for the charger. With Chameleon, the inverter and motor are the charger. The extra parts needed to complete a 44kW charger cost 150€. There is a significant weight savings too, as high power chargers are heavy.
44kW would charge an i3 in about 30 minutes.
3 phase 32A AC Charging Stations in Munich:
http://www.swm.de/english/company/in...-stations.html
Non-technical overview of charging:
http://www.plugincars.com/fast-charg...rs-125421.html
Renault's Patent:
http://www.google.com/patents/US2012...ed=0CEAQ6AEwBA
Renault Zoe reservation #313
The models and equipment (standard and optional) illustrated in this post reflect my misunderstanding of vehicles supplied by BMW AG to the German market. In other EU member states, the truthyness of my posts may vary. Please ignore this post. Subject to change.
More about Chameleon charger. Will BMW use it?
BMW-40-Years-Electric-Mobility 1BMW-40-Years-Electric-Mobility 2BMW-40-Years-Electric-Mobility 3BMW-40-Years-Electric-Mobility 4BMW-40-Years-Electric-Mobility 5BMW-40-Years-Electric-Mobility 6BMW-40-Years-Electric-Mobility 7BMW-40-Years-Electric-Mobility 8BMW-40-Years-Electric-Mobility 9BMW-40-Years-Electric-Mobility 10
