How to reset code - Bimmerfest - BMW Forums
Old 12-11-2012, 04:45 PM
SDS 14 SDS 14 is offline
Mein Auto: 07 335i Cabrio
How to reset code
Hi there, I took out my drivers seat in my 07 335i Cab in order to clean the carpet completely. In doing so I disconnected the snap in wiring connection. After reinstalling the seat and connecting the wiring my "No Seatbelt Display and "Airbag Not Working" dash lights come on and stay on whenever I drive my car. Does anyone know how to reset this or do I have to take it into the dealer? Thank you
Old 12-11-2012, 05:37 PM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is offline
Flying monkey herder
Mein Auto: Daihatsu Terrios
you will need to bring it to the dealer or another shop that has a bmw specific diag tool that can reset the airbag system.
FYI, IIRC, the seat bolts are single use bolts, so those should be replaced as well. they arent that expensive, under 2 dollars each.
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Present: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL
Old 12-11-2012, 06:01 PM
Thanks for the info. Cheers
Old 12-11-2012, 07:31 PM
DSXMachina's Avatar
Bimmerdex 7.4!
You are absolutely certain you reconnected all the wiring? Was your key off the whole time? Or...were you listening to some tunes while working and had the key in the accessory position (engine off, dash lights on)?
If the key was out the whole time then you should not have to reset the SRS lights. There would most likely be a wiring harness or connection problem. If you had the key on even for an instant, then see Orient's post above.
Old 12-11-2012, 07:38 PM
Nordic_Kat's Avatar
Nordic_Kat Nordic_Kat is offline
(oO (||||) (||||) Oo)
Mein Auto: 2009 328i E93 MT
Just curious SDS, but why did the seat have to completely come out of the car to clean the carpet? When we installed the euro first aid kit under my passenger seat, we had the seat tilted back at pretty much a 45 angle and still on its tracks. Besides, as you probably are well aware of, underneath the driver's seat isn't much carpet, mostly just a speaker.
If your sport doesn't put blood, dirt or grease under your fingernails,
then it's just a game.
Euro Modded|Split Armrest|Rear Foglight Mod|BMW Performance Exhaust|CDV Delete|Shark Fin Antenna Delete|Front Reflector Delete|LUX H8 Angel Eyes|328i|3 Pedals|Das Fahren im Freien
Old 12-12-2012, 09:30 AM
I didn't have the key on for the radio etc. but the remote was likely in the vicinity and perhaps that could seem like the same thing.
Old 12-12-2012, 09:38 AM
Your right about not needing to take the seat out completely for cleaning the carpet Nordic Kat but I also was doing a leather seat repair as the side bolster had become scuffed and needed to be sanded and painted. A a result it became much easier to have the seat on a work bench to perform the work. I didn't take out the passenger seat as I was able to clean the carpet without doing so. FYI the product I used for the seat repair was from Leatherique in Niagra Falls Canada. The products, cleaning agents, leather prep and paint worked flawlessly and the paint was a perfect match.
