Old 12-11-2012, 05:14 PM
MattH7086 MattH7086 is offline
Mein Auto: 545i
Exclamation In too deep with my first bimmer?!?
Ok so here is the situation and hopefully someone can guide me in the right direction or shed a little light my way. I just bought a 2004 545i as my first BMW since i got a little too impatient trying to find the exact 535i i want. I got the car for a killer deal but simply cause the dash is inoperable and the bumper is damaged. The car will not start and as me being new to this type of vehicle i was wondering if the dash somehow controls more than just the odds and ends of the electrical system. Simply put, does the dash not coming on keep this car from cranking or is it something more expensive
Old 12-11-2012, 06:52 PM
TLO03's Avatar
TLO03 TLO03 is offline
Mein Auto: 08 535 xit
I would invest in a Bavarian tech cable... your possibilities are endless.. you need to present codes. With out codes your only guessing.
Old 12-11-2012, 07:16 PM
Mein Auto: 545i
Ok thanks goes the info. Is is pretty much the same scenario with flooded out BMW's since just about every one I run across says the dash is inoperable so they can not test the vehicle. I'm not looking for the cheap escape by any means but just wish I was more knowledgeable as to what all the dash cluster prohibits you from starting the vehicle
Old 12-11-2012, 11:32 PM
2chill's Avatar
2chill 2chill is offline
Mein Auto: 2008 528XI
Did the car ever start since you bought it or was it like that (not starting) at the time of purchase? You state the front bumper is damaged. Usually when these cars get into frontal accidents, the car shuts down and will not start for safety reasons.
PP, CWP, NAV, satelite radio, USB, Folding Rear Seats.
Old 12-12-2012, 04:21 AM
Mein Auto: 545i
Yes the car was like that when I purchased it. I was thinking that it was a simple electronics issue and a few days in the body shop but now not so much lol. If in fact it was this, how would I get this safety feature to shut off after I got the front repaired?
Old 12-12-2012, 04:37 AM
dolfan13's Avatar
dolfan13 dolfan13 is offline
Mein Auto: 545i
Find out which module controls this.This is a great forums but the guys on the 7 side seem to have dug into their cars more.Hint.Also don't know if I can mention this but 5series.net has a wealth of knowledge also.Sorry if that against the rules.
Old 12-12-2012, 04:46 AM
Mein Auto: 545i
Thanks I appreciate all the advice and hope that I can get this thing at least alive in the dash! Also quick question since it has me curious, I noticed all flood damaged BMW's have a non working dash which makes it to where you can not start the car. Maybe these are two of the same problems just different scenarios?
Old 12-12-2012, 04:49 AM
dolfan13's Avatar
Mein Auto: 545i
Maybe the same issue ,you got me curious and found a video on you tube of someone with an e60 and the ole water in the trunk problem.I know if these modules get wet you can have all sorts of problems.The modules under the spare tire foam.
Old 12-12-2012, 05:10 AM
Mein Auto: 545i
Hmm so it pretty much all ties back to the modules. Seems all the modules are linked in to be a safety mechanism. Guess that's why ppl don't buy flood damaged vehicles lmao
Old 12-12-2012, 05:21 AM
dolfan13's Avatar
Mein Auto: 545i
I would try unhooking just the modules in the trunk and see if it will come to life.Start or try to start that is.
Old 12-12-2012, 05:45 AM
DAI's Avatar
DAI DAI is offline
Gap Filler for a M6 GC?!?
Mein Auto: '10 550i M-Sport
If you have no power, did you check the battery safety terminal that disconnects in accidents? Grab an old E60 brochure from BMW's website or the web, and near the back it gives a brief description of this feature.
Old 12-12-2012, 06:20 AM
Mein Auto: 545i
No i haven't tried to locate the battery safe terminal but definitely will do some research on my model to see where it is located & hopefully thats it.
@ dolfan13, this car wasn't flooded and the impact was on the front right smashing the headlight and bumper so i think the trunk module should be ok but maybe there is others like it in the front?
Old 12-15-2012, 08:34 PM
H F H F is offline
Mein Auto: 2005 545i
Open the battery compartment, check the battery disconnect feature, its right there at the batttery positive terminal covered with red plastic the cable comes from the left side from under the trunk matt... if it has disconnected do to an accident, u can see if it is disconnected it just hangs out. its right there, just plug it back in..( u will have to replace it )then the car should start. u just have to push it back into the positive terminal.
i had to do that once,, cause i did a battery change and didnt tighten the battery tight enough and the terminal got hot and melted the red plastic cover,and activated the disconect safety feature while i was on the freeway doen 120 mph at 4;00 am ...after i pulled over and turned off the car.. i tried to start the car and it would not start.. so when looking at teh battery i noticed the cable was disconnected,,, i plugged it back in ... and ,,,, bingo bango the car started !!.. the disconnect cable runs all the way to the starter and cuts off power to the starter in an accident... hope that helps....
Old 12-16-2012, 02:48 PM
Mein Auto: 545i
Update
Well I sold the car and got almost all that I paid for it, looks like I have to keep my eyes peeled for a 2010 535i white with sport package now lol thanks for all the help and advice guys.
Old 12-16-2012, 07:48 PM
2chill's Avatar
I hope you learned a valuable lesson from all of this. Never buy a car that doesn't start....
Old 12-17-2012, 05:45 PM
Giowizzy Giowizzy is offline
Mein Auto: 525xi
Originally Posted by 2chill View Post
i hope you learned a valuable lesson from all of this. never buy a car that doesn't start....
+1
Old 12-20-2012, 02:30 PM
KNKLHEAD KNKLHEAD is offline
Mein Auto: Bridgestone B330
I would have liked to see what the results were of reconnecting the safety terminal!
Old 12-20-2012, 07:03 PM
H F H F is offline
Me too.. woulda been worth a try
Old 12-21-2012, 09:07 AM
Certainly that small check *could* have been worth thousands!
