Old 12-12-2012, 01:47 AM
Aniq Aniq is offline
Mein Auto: BMW 525i 2007
RPM sudden drop/ jerk at idle
I own a BMW 525i, 2007 (E60), done 41000 miles. At the cold start up takes the RPM to 1000 and then slowly starts coming down. At about 700 rpm it suddenly takes a sudden dip to below 500 and quickly jumps back to 600-or 700. Then its settles at 600 or about. The car also does the same when it is at idle say at a traffic signal. it can take a sudden jerk from 600-700 to below 500 and again back.
BMW service center insist that some sensor is to be changed. earlier they replaced the fuel sensor but it did not help. Now they want too change the NO2 sensor. Expensive proposition that is. Anyone who has the same experience and may have resolved it may advise.
Old 12-12-2012, 02:23 AM
UltimateDriving UltimateDriving is offline
Mein Auto: A Car
I have a MY10 N52K engine that i don't drive a lot (17K Kilometers) and it does the same, although it does not drops as low as yours.
On the first 2 seconds of cold starts it usally has unstable idling between 1000RPM - 800RPM . . . just the first 2 seconds after that it idles fine.
Old 12-12-2012, 06:59 AM
DAI's Avatar
DAI DAI is offline
Gap Filler for a M6 GC?!?
Mein Auto: '10 550i M-Sport
I had an '01 3-series with a similar problem years ago, and the dealer fixed it with a software update. 41 K seams low mileage to replace O2 sensors. If the car is not throwing codes, I'd be hesitant chasing sensors when paying for each one out of my own pocket.
Old 12-14-2012, 01:41 AM
Well the BMW service centre only reelies on the computer diagnostic and that can throw up multiple codes.
Old 12-14-2012, 04:27 AM
DAI's Avatar
DAI DAI is offline
Did they tell you what codes are coming up?
525i, cold start, e60, idle problem, rpm drop
