The X5 SAV Forum
Old 12-12-2012, 04:42 AM
x5Espana x5Espana is offline
Mein Auto: X5
X5 key won't start the car
My X5 (2004 3.0 Diesel) has been off the road for about a year and I have replaced the battery but the it won't start. The key will lock/unlock the doors but nothing when I try to start it. I have only one key and during the time it was off the road my son dropped the key and it fell apart, I have put it back together and like I said it locks/unlocks but nothing when I turn the ignition, no click from the starter motor, nada.
I have researched the forums and I wanted to ask about the 10 second thing re the immobiliser, if I lock the car and then unlock it and try to start it within 10 seconds should this work, so I can at least move the car. secondly do I need to order a new key or is there any other solution.
Many thanks in adavance.
Old 12-12-2012, 10:14 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
The EWS system might be faulty in that key. Try opening it to check? Might need a new one, unfortunately.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by hornhospital View Post
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
Old 12-12-2012, 05:37 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
When the key was dropped it could have broken a solder joint for the EWS transponder. That EEPROM must be able to communicate with the EWS control module & DME/ECU. And it also needs the charging coil to operate...and that may have been damaged as well. Looks like you need to do some surgery and go back in....or get another key.
Q {BMW CCA Member #191509}
(SOLD)
