Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Do-It-Yourself H.Q.
Do-It-Yourself H.Q.
Share your DIY projects that have helped you keep your BMW running. For questions about how to fix your BMW use the model specific forums. All BMW DIY tips, tales, and projects discussed inside. Learn to work on your car and know the right BMW parts you will need!
Old 12-12-2012, 07:15 AM
morfinx morfinx is offline
Shenanigans
Mein Auto: 2009 Z4 sDrive35i DCT
DIY: Front License Plate Bumper Plugs
Many people have cars that have front license plate bracket that are drilled into the bumper, either by the dealer or by a previous owner. Case in point, my car:
Most people would agree that a car looks better without the bracket. I was always a little bit leery about going without since TX law requires a front plate. However, due to a (unintentional??) change to the law earlier this year, not having a front plate no longer has any punishments. So I decided to finally do it. But the problem is, what to do with the holes in the bumper? There are several options:
1. Use bumper plugs
2. Fill the holes yourself with fillers and paint over them. In fact, there is an excellent DIY guide here: http://www.e90post.com/forums/showthread.php?t=755220
3. Get your bumper professionally filled and repainted
4. Buy a new bumper
Like many people, I decided to take the easiest and least expensive route, with bumper plugs. Most people order theirs from bumperplugs.com. However there are disadvantages:
1. Not super cheap - they charge $25 per pair plus $8 shipping. (Although after making them myself, I understand the amount of labor it takes. So now I don't think it's unreasonably priced)
2. They require you to ENLARGE the existing holes. This means the operation is not reversible - you cannot reinstall the license plate bracket after the fact.
3. Their plug caps, in my opinion, are quite large.
So I decided to make my own.
Step 1: Take the front license plate bracket off to assess the damage.
OUCH! Not only are there 4 holes instead of 2 (bottom 2 are not necessary due to the bracket's design), the edges of the holes are raised up due to the use of self-tapping screws.
Step 2: Remove the raised edges around the holes.
We want to remove the raised edges because we want the plugs to be able to sit flush with the bumper. Using an x-acto knife, VERY carefully trim away the raised edges around the holes. Do not trim too deep into the holes, as we still want to be able to reinstall the license plate brackets later if we need to.
Step 3: Purchase the plugs.
I would recommend going to Lowe's. I went to Home Depot, Advanced Auto, and Lowe's. Home Depot didn't have anything, Advanced had a small selection, where as Lowe's has a ton to choose from. I picked up the two smallest GM trim fasteners:
They are both made by Hillman, one is 881201, the other is 881192. The both have the same sized stems, but one has a larger diameter but flatter cap whereas the other has a smaller diameter but thicker cap (you will see in the later pictures). I bought 6 of each, in case I break any in the process (I ended up breaking one of the bigger ones). Ignore the one in the orange box, that's from Adanced Auto and is the same as the Hillman 881192 from Lowe's.
Step 4: Trim the stems.
Since I did not want to enlarge the existing holes, I needed to make sure that the plugs fit them. They do not - they are too big. So I used a dremel to carefully trim down the plug stems. To make sure I trim them down to the correct size, I used one of the self tapping screws I took off from the bracket and drilled a hole in a plastic CD spindle cover and used the hole as a size guide. Be careful not to use too much force, the trimmed down stems can break if too much force is applied. That's how I broke one of the plugs. Results:
Step 5: Paint prep.
Get a cardboard box, drill a bunch of holes in them ( I used the self tapping screw), and then put your plugs in it.
Step 6: Apply primer.
You can get all of your touch up paint supplies from paintscratch.com or automotivetouchup.com. You can also get them from a number of other places online. The primer and the clear coat you can get locally in your auto parts store, but the base coat needs to match the exact color of your car, so you will have to order it from one of those aforementioned places, or from the dealership's parts department.
Apply the primer to the plugs. I used a touch up paint bottle brush here. One coat is enough, as long as it covers all of the bare plastic surfaces.
Step 7: Apply base coats.
Wait about 30 minutes to let the primer dry. Then apply 2 coats of base coat, waiting 30 minutes between each coat.
I used a touch up pen here, because that's all I had at the time. DO NOT USE A TOUCH UP PEN! They are terrible and you will never be able to put down an even coat with it on anything other than a tiny scratch. Use a brush instead (or even better, spray it with an air brush if you have the equipment).
Step 8: Apply clear coats.
Let the base coats dry over night. The next day, apply 3 coats of clear coat, waiting 30 minutes between each coat. You can also do 4 coats, but no more than that.
Step 9: Wet sand and polish.
Let the clear coats dry for two to three days.
Put some water in a bucket. I added some Optimum No Rinse for lubrication, but you can also use a few drops of dish soap. Soak a piece of 2000 grit sandpaper (I used 3M) for 15 minutes.
Wet the surface of the plug cap, then use the sandpaper to lightly sand the surface back and forth in a single direction. Stop to rinse the cap frequently. I sanded each plug for about a minute. Dry with clean microfiber towel. At this point the paint surface should look hazy.
Now use a polishing compound to polish the paint surface. I used Meguiar's Ultimate Compound. Dab a little bit of the compound on a clean microfiber towel. Use medium pressure (careful not to break the plugs) and polish in a circular motion for about 90 seconds for each plug.
Final product:
Step 10: Test fit.
Now that we have two sets of finished plugs. Let's go test them!
Turned out that I trimmed too much off of the stems and the fit is quite loose. No problem, it lets me do the test fit easily.
Smaller/thicker plugs:
Bigger/thinner plugs:
After comparing the two, I decided the smaller plugs looked a little bit better.
Step 11: Final install.
Since the stems were too small, which resulted in a loose fit, I wrapped thread seal tape around them until they were thick enough for a secure fit in the holes. The end result:
As you can see from the picture, it's barely visible at close range and completely invisible further away. I did a some highway driving just to test the fit and the plugs didn't budge at all.
It's a lot of work to be sure, but I'm pretty happy with the results
2009 Z4 sDrive35i DCT, AW/CR
2010 335i Coupe 6MT, SG/CR [SOLD]
Old 12-12-2012, 03:35 PM
BMWZ4RIDER BMWZ4RIDER is offline
Z4 35i Rider
Mein Auto: 2009 Z4 35i
Great DIY and easy ( with patience) to do. I am going to make a set of these as a 2nd set. Thanx for the write up.
2009 BMW Z4 35i/Space Gray Metallic/7 Speed DCT/Premium,Cold Weather & Premium Sound Packages/Nav/Comfort Access/Ash Grain Interior & Dash Kit/AntiTheft/SportWheel/PDC/WindDeflector/Black Kansas Leather/Smoked Reflectors, Side Markers & 3rd Brake Light/Ferrari Red Brake Calipers/Clear Front Mask/Gloss Black Grill Inserts/6000K LED Lighting/De-Badged/Aluminum Pedal Set/Real Carbon Fiber BMW Door Sills/CF Wrapped Engine Compartment Roundels,F Lower Grills & Center Wheel Caps.
Old 12-18-2012, 06:08 AM
Carl3 Carl3 is offline
Mein Auto: BMW
Nice work! I love these D.I.Y stuff
Old 12-18-2012, 09:29 AM
Shenanigans
I think it's much better than buying pre-made bumper plugs
Old 12-22-2012, 06:44 AM
Z4 35i Rider
Thanx to Morfinx and this DIY I completed my Bumper Plug project. See my before with the use of double ended screws and topped off with SS Acorn nuts. It looked good but was not the clean look that this DIY offers.
I followed this Thread instructions. I primed and then painted with my BMW touch up paint set. The only thing I did different was instead of cutting off the protruding plastic on the hole, I used a low setting heat gun, placed duct tape oved the hole, lightly heated the plastic and pushed the protruding plastic flush with the bumper with a flat piece of soft plastic. Therefore I did not en-largen the hole. This made it smaller.
My only suggestion to all doing this to and as outlined by Morfinx:
1. Sand the plastic caps down very well before prime.
2. 2 light primer coats and wet sand very lightly in between.
3. 2 Light coats of paint again with sanding in between
4. 1 light coat of clear.
Heavy paint coats will bulid up and as I found out pop off the end of the plug when under pressure while installing.
I too made an extra set of 5 for future use.
Name:	Original Bumper Hole solution.jpg
ID:	354169   Click image for larger version
Name:	Bumper holes.jpg
ID:	354170   Click image for larger version
Name:	bumper plugs painted.jpg
ID:	354171   Click image for larger version
Name:	Painted Bumper Plugs Installed 2.jpg
ID:	354172   Click image for larger version
Name:	Painted Bumper plugs isntalled 3.jpg
Old 12-22-2012, 01:22 PM
Shenanigans
Well done! Looks good! I read that you should not sand between coats, but for something this small it probably doesn't matter. I also did 3 coats of clear for increased paint protection. Had them on the car for a month now and no problems
Old 10-19-2014, 11:08 AM
gauge370 gauge370 is offline
Send a message via ICQ to gauge370
Mein Auto: 2008 528 Xi
Great post. Thanks for the directions and the pics. I'm starting the process for my 528 xi this week.
Old 04-23-2015, 04:01 PM
capelleti capelleti is offline
Mein Auto: 2013 BMW 335i
Great idea; unfortunately, the law was subsequently amended in September 2013. Failure to have a front license plate now yields a $200 ticket in Texas.
