Old 01-18-2013, 09:38 AM
DHoang's Avatar
DHoang DHoang is offline
Gearhead
Mein Auto: '98 528i, '82 323i
did he tell you what exactly this update will do for your car?
also, w/ the too much play diagnosis on the fan clutch, is it loose bearings, or is it
too much play on the viscous clutch ? If it's bearing related, you may want to
change this asap, rather than later.
http://www.bimmerfest.com/forums/picture.php?albumid=4132&pictureid=24642
Old 01-18-2013, 09:45 AM
Josh P.'s Avatar
Josh P. Josh P. is offline
Bimmerholic
Mein Auto: 2001 530 SP/PP/CWP/Slush
After I noted that the aux fan had been coming on, we opened up the hood up and he just grabbed the fan while it was running, felt for resistance, and made the diagnosis. As soon as I noted the aux fan was kicking in he said this happens when the rad fan is not cooling the engine sufficiently. I guess I will check it myself. The coolant temp needle never gets beyond 12 o'clock so it does not seem like this is a pressing issue, but if there are other things to check, let me know.
He didn't say exactly what the update would do. He wasn't pushing me to do it. He said sometimes it will fix small engine/performance issues, presumably like them one I am having.
2001 530 Steel Blue Metallic, purchased Dec 03
SP/PP/CWP/Slushbox (I know I know)
OEM M5 bumper, 40% Huper Optik ceramic tint, Dice Silverline Pro iPod adapter, 540SP radial spokes, Zimmerman Z-Coat rotors w/ Hawk HPS pads
"Mods": driveshaft, cooling system, Vanos, CCV, PSR, VCG, FSU, spark plugs, buncha belts-n-hoses, & other things I'd just as soon forget
BMW CCA member for 15 years
Old 11-12-2014, 07:57 AM
moggen moggen is offline
Mein Auto: bme 540ia
Update please??? tired of threads with no final answers to the problem..
Old 11-12-2014, 08:09 AM
Josh P.'s Avatar
Bimmerholic
Ha ha! a few things.
1) I paid for the software update (about $100) perhaps 9 months ago. Since then: No codes at all! So, whatever was causing this imbalance in fuel/air, it has gone away. The mileage now seems normal, in excess of 30 MPG on highway. No vacuum leak or any other issue.
2)Also since then, my radiator cracked, right down the side. (That's covered in another thread here). Since is was only 3 years old, I think that was owing to a bad fan clutch: the aux fan was coming on all the time, which means the engine was too hot, which means the radiator was too hot, which means it failed prematurely. Anyway that's my theory.
About to hit 80,000 miles. Not bad for a 14 year old car!
Old 11-12-2014, 08:13 AM
Okey! thanks for the reply my 540ia-99 have almost the same problem that you had.. with P0100 pending code.
gonna try to clean with som MAF cleaner if that doesent help i have to replace it..
